All Things Mk5 => Mk5 General Area => Topic started by: Reeceyy on May 10, 2024, 03:37:24 pm
Title: WTF!! Has my car been mapped?? :|
Post by: Reeceyy on May 10, 2024, 03:37:24 pm
I changed my diverter valve today. I was getting a p0299 code coming up and researched that it could possible be that (my old one was horrendous!). Today i changed it and then when for a drive.  ---- The thing wheel spins all throughout the rev range in 2nd!! Even the sound is different! I mean wtf!! The difference is monsterous! I have vcds so i checked to see if the ECU has been flashed and this is what i got:
What could youse be able to tell me about this?
(https://i.postimg.cc/sxh3JRPH/Imagen-de-Whats-App-2024-05-10-a-las-16-25-05-88652fe0.jpg) (https://postimg.cc/p5PN246K)
Title: Re: WTF!! Has my car been mapped?? :|
Post by: pudding on May 10, 2024, 05:12:50 pm
That it's been flashed twice.  With what is anyone's guess.  Could be a dealer update, could be a remap.  Not even VW can tell you what it is, only that the checksum is different to factory.
Log the boost pressures and see what the requested is. If it's much higher than stock, there's your answer.
Post by: ZoliWorks on May 10, 2024, 10:07:19 pm
Your car is stage 1/2 mapped. With a stock tune, there's close to no wheelspin. With a stage 1 tune AND a broken turbo, I was spinning all the way in 2nd gear. I could come off throttle then floor it again and it would spin again.
Post by: Reeceyy on May 10, 2024, 11:06:18 pm
Yeah my turbos got a crack in it too! What bhp you reckon it could be running??
Post by: ZoliWorks on May 11, 2024, 12:06:31 am
With VCDS, look at boost specified, boost actual, intake air mass g/s and actual torque. You can use intake air mass and torque to estimate BHP. Take the car for a pull in 3rd gear from 3k to 5.5-6k and you should get a good enough reading. Or if you can do the same in 4th gear, it's even better.
My cracked k03 turbo, on a stage 2 map, was underboosting by 0.3-0.4 bars throughout the powerband and making somewhere between 220-230hp
