All Things Mk5 => Mk5 General Area => Topic started by: slipd on May 18, 2024, 07:54:09 am
Title: Tailgate won't lock - actuator issue?
Post by: slipd on May 18, 2024, 07:54:09 am
Hi guys,
Just tried to shut my tailgate, after successfully opening it, and it won't lock. There is also no electric sound coming from the actuator. The rest of the central locking (4 door) is fine.
The tailgate is showing as open on my dash and I have no rear wiper. Thoughts at this stage?
I'm just keen to get the tailgate locked at the moment, for security. Isn't there a manual override on the reverse of the tailgate?
2007 1.6 FSi.
Thanks in advance!
Title: Re: Tailgate won't lock - actuator issue?
Post by: Lewo on May 18, 2024, 08:45:10 am
Check the wires from tailgate into the car left hand side, sounds like some of them have issues.
Post by: slipd on May 18, 2024, 09:07:23 am
Thanks mate! Will do. I recall moving the rubber wire boot last year to clean around the inside of the tailgate and thinking how clean and tidy everything looked there. I've seen on some videos, is it the earth wire that can get brittle and break? It's weird how I'm getting some sort of electrical noise from the actuator though/tailgate open warning on the dash. That's what made me think the actuator was at fault. I had to replace a couple of the door actuators the other year that had started to make weird noises and not always open/lock.
I've just tried to use the emergence lever to lock the tailgate but it's not having any one it, so as it stands, I can't actually lock the tailgate... any ideas with that? - just need a quick fix in case I can't get sorted for a for days.
A quick check for fault codes has revealed nothing.
Post by: mjmallia on May 18, 2024, 09:39:16 pm
As mentioned, it will be broken wires on the left boot hinge
Post by: slipd on May 21, 2024, 10:10:28 pm
Thanks all, happy to report it was only the actuator... £10 from eBay compared to £85 from the dealership. Twenty minutes to fit :happy2:
Post by: Lewo on May 22, 2024, 07:54:37 am
Good news  :happy2:
Post by: mjmallia on May 22, 2024, 08:09:33 am
Well done.  Not heard of the actuator failing before.......always been the wires breaking in my experience  :happy2:
Post by: OldGTI on May 22, 2024, 06:47:13 pm
I did mine last year. It was high level brake light that failed on mine. Not to bad to diy just replace one wire at a time.
(https://i.postimg.cc/T1xXwLpV/F900-A501-2-DD9-403-D-8429-6-C330264-AE8-B.avif) (https://postimg.cc/jwM13j62)
Post by: slipd on May 22, 2024, 08:09:59 pm
Wow! Is it possible to replace the entire loom?
Feels like I got off lightly with just the actuator :smiley:
Post by: mjmallia on May 23, 2024, 09:20:42 am
It happens to all Mk5's at some stage in its life unfortunately......due to the lack of slack in the loom.
It is a pain if you have more than one wire broken as they are white mainly,
Post by: OldGTI on May 23, 2024, 01:48:17 pm
Yes you just have to strip the boot-lid and the nearside pillar to get to the connections. I did mine after my auto electrician showed the the broken wires and cracked insulation.
(https://i.postimg.cc/hjTGfTNS/BC3710-BC-402-F-47-BC-A1-ED-BC66528-DEFBF.avif) (https://postimages.org/)
