All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Hayden on July 24, 2024, 11:07:19 am
Hi all, I have a stock Mk5 gti on just under 90k.
Recently had my first engine management light pop up on the dash while driving. Took it to a garage for diagnostic but they just cleared the light and told me to come back if it returns (not sure I'll be going back). I have a picture of the diagnosis and was wondering what peoples opinions are on continuing on driving. I need to do around 200miles this weekend but are comprehensive about driving it. The diagnosis results are in the attached photo. Thanks in advance
(https://i.postimg.cc/Wbq3NQtx/IMG-20240723-102505.jpg) (https://postimg.cc/N5YYbC6x)
Wouldn't worry about that code, its either the charcoal canister, purge valve not working an air leak on a pipe or the fuel cap is leaking.
Agree with above. I wouldn't worry about P0441. Just cancel the fault. Likely faulty purge valve or charcoal canister.
The purge valves tend to stick with age. Simple fix, but not a seroius problem.
https://www.ebay.co.uk/itm/185674375292
Thanks for your advice. I'll look into the purge valve. How about the other code about the coolant fan, is that of much concern? I haven't noticed the car overheating if that's what it would cause.
You don't get fuel trim adaptations when the purge valve fault codes, so I would get that sorted sooner rather than later. Start in the order of cost - Fuel cap, purge valve then charcoal canister (genuine). Sometimes replacing all 3 is the only way to get rid of it.
Check both fans are spinning with the air con on. If they are, park that until you get back from your trip.
I didn't know that. Might be why my old Ed30 drank fuel :scared:
:grin:
It's a German car buddy. Anything emissions related - adaptations = denied :grin:
