All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: Andy on April 24, 2010, 09:16:50 pm
for a while now the n/s/f door won't open from the out side when i unlock the car,but it will open from the inside..if i spray the mechanism with wd40 it locks and unlocks ok for a while then it does it again..got the car scanned today..is this a easy fix and what will i need
VIN: WVWZZZ1KZ5W160387 Mileage: 66910km/41575miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 KC HW: 028 101 190 3
Component: R4 2,0L EDC 0000SG 8457
Revision: 12345678 Serial number: VWZ7Z0D1201563
Coding: 0000072
Shop #: WSC 00784 210 86038
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023170
Shop #: WSC 01392 785 00200
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AC
Component: ClimatronicPQ35 066 0404
Shop #: WSC 00000 000 00000
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001252733
Coding: E5898F0600041800001400001400000000087F075C
Part No: 1K2 955 119 B
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Part No: 1K0 955 559 M
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00000
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
Component: 08 AIRBAG VW8 013 2100
Revision: 02013000 Serial number: 0033HD027AV0
Coding: 0012344
Shop #: WSC 01373 785 00200
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 521 0050
Coding: 0000012
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 872 K
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0003403
Shop #: WSC 12345 123 30350
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 2700104B180177
Coding: 3D3F0B00070003
Shop #: WSC 07975 795 00500
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Component: IMMO VDD 4312
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0148
Coding: 0000052
2 Faults Found:
00932 - Electric Window Motor; Drivers Side (V147)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
01706 - Switch for Mirror-Adjust (E43)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.3 1502
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 BL
Component: 01 KSG 0301
Coding: 80C802087F2D0F0FC85FC69010
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Part No: 1K0 951 177
Component: Innenraumueberw.004 0101
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
012 - Electrical Fault in Circuit
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
End ---------------------------------------------------------------------
Saturday,24,April,2010,10:19:56:27638
VCDS Version: Release 908.2
Data version: 20100326
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 62 72 7D
Coding: 0000072
Coding: 0023170
Coding: 00065493
Shop #: WSC 00000
Coding: 00217125
Shop #: WSC 00000
Coding: 0012344
Coding: 0000012
Coding: 0003403
Coding: 0000052
2 Faults Found:
Coding: 0000052
2 Faults Found:
Coding: 0000016
Coding: 0000016
Saturday,24,April,2010,10:23:07:27638
Chassis Type: 1K0
Coding: 0000072
Readiness: 0 0 1 1 1
Coding: 0023170
Coding: 00065493
Shop #: WSC 00000
Coding: 00217125
Shop #: WSC 00000
Coding: 0012344
Coding: 0000012
Coding: 0003403
Coding: 0000052
Coding: 0000052
Coding: 0000016
Coding: 0000016
anybody :sad1:
I would say this bit is the starting place: -
Coding: 0000052
2 Faults Found:
Only one of those fault codes is listed - http://wiki.ross-tech.com/wiki/index.php/00929
