All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Smudgster on April 30, 2010, 10:59:38 pm
Title: New Stereo system lasted a day!!!
Post by: Smudgster on April 30, 2010, 10:59:38 pm
Took a trip up to see Oli off this forum on Sunday to collect the Blaupunkt AMp and stealthbox of him. Was well happy, got my stereo fitter to sort it all out along with an RNS 510. Collected the car late Wednesday Night and was happy with the improvement.
Well tonight I gave it a bit of VOLUME as a cool CHOON came on and now one of the front speakers is flapping its head off  :signLOL: :signLOL: :signLOL: :signLOL: :evilgrin: :evilgrin: :evilgrin: :evilgrin: So I now need to replace the front speakers!!
So my questions are:-
1. Go a 3way component set? (Had Hertz in my last car and wasnt overaly impressed)
2. Go a 2way component set?
Ideas and recommendations please, Have a budget of circa £300. The Blaupunkt amp is rated at 65 watts RMS
Cheers guys
Smudge
Title: Re: New Stereo system lasted a day!!!
Post by: DanoGTI on May 02, 2010, 10:09:14 am
I've got some 2-ways that I'm looking at putting in - cr@p weather so I haven't done it yet.
Doesn't really matter imho, as the GENIOUS designers at VW put the main driver behind the front seat!!  :congrats:
The soundstage ain't great.
I was lookin at using my 2 ways and potentially incorporating the 3-way crossover from the standard setup, and use the OEM midrange driver.....
Food for thought  :happy2:
PICS PICS PICS!
Dan
Post by: Garth on May 02, 2010, 10:43:14 am
Smugster, check the door panel first! I had a similar issue with the passenger side speaker vibrating and it acually turned out to be the door panel that was rattling. It sounded just like a blown speaker so I didn't look at it for ages, then I happened to have teh door panel off and noticed it was slightly loose. All tightened up and now there's no more vibration  :happy2:
Post by: Smudgster on May 02, 2010, 11:05:18 am
Deffo speaker gone!!! too much dizee rascal  :signLOL: :signLOL: :signLOL: :signLOL: :signLOL:
Thinking i going Focal 3 way components VR range for £300m had Hertz last time and they were ok but not great.
I got the OEM mid 4" was going to use it but tbh honest no good now with using the amp
Post by: Garth on May 02, 2010, 01:35:23 pm
Have you set your RNS up to output low level instead of standard high level?
You should do this when using an amp. I had to do re-code my RCD510 because I have the VW soundpack amp. I'm sure the blaupunkt amp should be able to run the standard speakers.
