All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: stuupnorth on May 01, 2010, 08:16:48 pm
Title: towbar wiring prob's
Post by: stuupnorth on May 01, 2010, 08:16:48 pm
Hiya Guys
Can anyone help???
Just fitted a detachable towbar and Specific Wiring kit
All bought from 'Towquipe'
fitting the towbar no problems
but the wiring thats a different story LOL!
it was a sort of 'plug and play' ie no cutting of loom just a couple of wires from the each of the rear
light connectors
Stu
Title: Re: towbar wiring prob's
Post by: jmspear on May 01, 2010, 10:05:12 pm
Hi Stu, I fitted a towbar to my 55 plate GTI. The issue is that the wiring is canbus and no power available from the rear lights.
I had to buy a switching box (technical term for it but don't remember what) it is needed for any canbus cars. I then ran power from the rear aux socket to the switch box, then you run links from each of the rear lights (indicators r & l, fogs, brake, side) to the relavant input on the switch box, then outlet from the switch box to the din trailer socket.
Then when the low voltage canbus operates a light it switches the box and supplies power from the live feed to the relavant pin on the din trailer socket.
Without a switching box you have no hope, hope it is in your kit!
Here is an example off fleabay http://cgi.ebay.co.uk/7-Way-Bypass-Relay-Towbar-Towing-Electrics-Protect-Car-/290419575387?cmd=ViewItem&pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item439e5b0a5b
HTH helps
John
Post by: stuupnorth on May 02, 2010, 01:15:23 pm
Hi John
cheers for that  :happy2:
maybe i was wrong in thinking the wiring kit would have it all
i'll sort that out when i give tow quipe a shourt on tues as i think they
are shut for the bank hoilday weekend
Cheers Again
Stu
Post by: stuupnorth on May 02, 2010, 03:10:44 pm
 :scared:
removed the wiring loom and now no rear drivers lights
no brake light rear lights,fog !!!!!!
HELP!!!! lol
passengers all ok!!
