All Things Mk5 => How to Guides / Troubleshooting => Topic started by: stuupnorth on May 06, 2010, 08:05:18 pm
Hi guys
Has anyone heard of this problem before??
Was told my local garage that the misfire i had was due to a faulty
ignition coil it was changed and then the guy said the car won't start!!!
the dealer has now said the ecu might need to be reset or at worse a new ecu!!!
Did you get this sorted?
Any joy with this????
I've seen fuses blow after faulty coils causing non start. May be worth a check
