All Things Mk5 => How to Guides / Troubleshooting => Topic started by: stuupnorth on June 15, 2010, 07:48:21 pm
Title: door handle
Post by: stuupnorth on June 15, 2010, 07:48:21 pm
Hi guys
Can anyone help me with this problem?
I'm looking to replace the passenger front interior door handle(3dr)
I know it comes in two parts an outer and the inner part with the
window switch
outer no prob's ,will i have to take the panel off it looks/seems to be fixed
somewher else as i have removed the screws but it won't budge
Stu
Title: Re: door handle
Post by: big al on June 16, 2010, 11:33:38 am
Are you reffering to the interior doorcard?
If so then there are a few screws, there are 2 at the bottom running parallel to the bottom of the door, one around the corner by the side mirror, and the 2 behind the handle once you remove the handle cover.
Then pull really hard, there are just clips holding the card in place after that.
Post by: cameluk on June 16, 2010, 01:26:05 pm
There are three lower screws on a 3 door
Take a look at this thread http://www.golfmkv.com/forums/showthread.php?t=82260 (http://www.golfmkv.com/forums/showthread.php?t=82260), its for a 5 door, but shows where the screws are located
