All Things Mk5 => Modifications & Technical Area => Track Day Technical => Topic started by: laurent.d on June 29, 2010, 10:40:59 pm
Title: Best track alignment set up?
Post by: laurent.d on June 29, 2010, 10:40:59 pm
Hi,
I wondering which set up you guys who use your car on track could advice.
I go to track only on the Nürburgring, I use road Pirelli P ZERO MO.
I'm easily around 8'40'' on this track.
My car was aligned by VWR, handling was fine and fun but quiet agressive.
I checked out alignement because I thought it as to much rear-and negative camber and I found out this:
Front:
Caster     L 7°41'    R 7°52'
Camber   L -2°14'   R -2°04'
Toe         L -0°09'    R +0°13'
Rear:
Camber   L -2°38'   R -2°45'
Toe         L -0°16'    R +0°06'
Rear camber is higher than front so we lowered it.
Toe front should have been 0°15' (both side) and rear 0°05' (both side) I dont know why it is not like that. Break in bushes or mistake, any way this is not my point.
After aligment we found out:
Front:
Caster     L 7°46'    R 7°57'
Camber   L -2°14'   R -2°05'
Toe         L +0°07'    R +0°07'
Rear:
Camber   L -2°01'   R -1°56'
Toe         L +0°10'    R +0°12'
So less camber at the rear, more even Toe ant toe in instead of out.
The car is more stable, far less agressive, maybe a bite more efficient but I miss the rear which turn around the corner.
So my question is which alignment do you advise?
Front Toe L +0 ° 15 ' R +0 ° 15'
Rear Toe +0 °05 'R +0 °05'
As VWR said it should be, or smothing else.
Title: Re: Best track alignment set up?
Post by: gillm on June 29, 2010, 11:17:54 pm
i run all my cars to the factory settings (they spent ages setting them up !) i messed around with my mk1 for years and it was a battle between staright line stability and floaty corners , so i now run it very close to std apart fro 2 degrees front camber
Post by: laurent.d on June 30, 2010, 08:02:07 am
Thanks for your reply GILLM.
Any other advice? Hurby? Tony Danza?
Post by: Janner_Sy on June 30, 2010, 12:26:26 pm
take it to a specialist chassis tuning place like centregravity or wheelsinmotion.  you tell them how you want it and thy do it.
I thought adding more rear camber would increase the rear grip in cornering, so if your running more rear camber tha the front, you should find it will be less likely to loose the back end as it 'should' understeer before over steer
Post by: laurent.d on June 30, 2010, 01:59:36 pm
Thanks VRSY,
But I live in France, so I can't go to centregravity or wheelsinmotion, otherwise I would go bake to VWR.
I went to a chassis specialiste in France but they work on any cars and are not specialist on MK5 platform.
My main concerne is about toe.
Do I stay close to OEM : 5' each side Front and 10' each sideRear
or 15' each side Front and 5' each side Rear as claim VWR and Jonny'c had on his Golf?
Post by: laurent.d on July 04, 2010, 11:38:22 am
No more advice?!!
My car is going to be aligned this week while I'll change the tyres.
As:
VWR claim        15' each side Front and 5' each side Rear.
Jonny'c said he hade                                       1,5mm  (11')each side Front and 0' each side Rear.
NeilM hade hes car aligned by Center Gravity Limited  11' each side Front and 5' each side Rear.
So I'm going to fit about 13' each Front and 5' each Rear.
So, I think I can't be wrong.
Post by: laurent.d on July 13, 2010, 06:44:29 pm
So I have my car aligned last week.
Now it is:
Front:
Caster     L 7°35'    R 7°41'
Camber   L -2°17'   R -2°04'
Toe         L +0°10'    R +0°10'
Rear:
Camber   L -1°56'   R -1°51'
Toe         L +0°05'    R +0°05'
They didn't want to go over the OEM front spec Toe which is 10'
As they didn't want to spend some time to balance my front camber for only 10', I think I will do it my self and then proceed to the alignment myself with the old school method (string alignment)
I will found out within 10 days at the Ring how it handle.
To exonerate VWR, we had the surprise that front alignment was wrong again while it have been done only a few weeks ago.
We found out that explanation comes from tyre wear.
Between VWR alignment and previus alignment in France the tyres have been permuted and were about 21000 km old. Since, previus alignment and last one, we just fited brand new tyres all around.
So no VWR mistake and no break in bushes.
Post by: danishmkvgti on July 23, 2010, 09:00:55 am
any updates on this??   :smiley:
Post by: tony_danza on July 26, 2010, 11:09:11 am
I can't remember the exact numbers, but I had this:
Rear.
1/2degree less camber than the fronts
Parallel toe
Front.
As much caster as you can get
Your preferred camber, 2 degrees is ideal IMO.
1.5 combined toe in
It'll feel like the rear is a bit alive and loose, but loose is fast.
Post by: the bruce on June 24, 2011, 07:06:06 pm
I just found this topic today.
I'd prefer the VWR recommendation (nice to see they recommend similar adjustments like I do).
If you like to have more camber don't be afraid to adjust more toe in as well.
1. rule is:
The more camber the more toe in you'll need to have proper tyre wear.
2. rule:
More toe in on front gives quicker turn in, more toe in on rear provides more stability.
 :wink:
Post by: _Nathan_ on June 24, 2011, 08:55:29 pm
Are you sure more toe in on the front gives better turn in? It is the exact opposite to what I'd have expected based upon setting up my other car. On that toe out makes the turn in miles better. Unless FWD is that much different? If so do you know the physics behind why it is so different?
Agree on toe in at the rear for stability though!
Post by: the bruce on June 25, 2011, 01:12:03 am
Yes, guess I do know.  :smiley:
I don't which kind of car your other one is (I guess rwd?).
It depends a bit on ackermann geometry (like road cars) or not (like true race cars).
But generally toe in on front improves turn in.
Why?
The reason is dynamic weight distribution.
When cornering weight moves to the outer wheels.
Imagine first you'd have toe out on front:
When you turn your steering wheel a bit the inner wheel turns in first, the outer
wheel is just directed out or straight. This causes in the moment when the weight
goes to the outer wheel the 'turn in' is slowed. If you turn the steering wheel even
more the cars turns in.
Now with toe in on front:
When you start turning the steering wheel the weight goes to the outer wheel
which is already slightly 'turned in' and so this helps for quick turn in. This gives
usually a much better steering feel.
You got it?
Toe out on front has a stabilizing character. That's why bumping in causes the
Golf front axle to toe out esp. when braking hard.
One more reason for even more toe in on front:
For low tyre wear the front steering kinematic needs to be according to Ackermann.
This means both wheels follow the same center poit with their own radius.
That's good for road cars used in narrow cities.
Unfortunately driving fast through corners requires more steering angle on the
wheel that has more weight. This is the outer wheel!
That's why true race cars' steering systems are desgned 'anti-Ackermann', so their
outer wheel turns more than the inner wheel.
Retrofitting this on a street car isn't easily possible. But more toe in helps coming
closer to this. So more grip and less understeer as well.
Porsches have a neutral steering. No Ackermann, no anti-Ackermann.  :wink:
 :driver:
Last not least a third reason:
It is common knowledge that if you increase (negative) camber you have to increase
toe in as well to provide even tyre wear.
edit:
Even more, the VAG PQ35/36 platform front suspension goes to massive toe out
when bumping in (you can see it when lowering your car before alignment).
So the outer wheel will do so when turning. The softer the bushes the more.
This helps to stabilize the car when an unskilled driver needs to brake and/or
needs to turn in an emergency situation cos this causes understeer and slowes
the steering. On track or for fast raod applications we don't want this behaviour
or at least less of it. We want less understeer.
http://tesis-dynaware.com/fileadmin/Downloads/Referenzen/VW_ATZ_Messdatenbasierte_Fahrdynamiksimulation.pdf
Post by: _Nathan_ on June 25, 2011, 10:29:29 am
Yes, RWD, It is based on a road car though rather than a proper single seater race car. That was my question really - why is it different for the golf platform compared to other platforms (including other FWD platforms that would run toe out for better turn in).
Post by: the bruce on June 26, 2011, 09:41:17 am
- edited last post -
 :wink:
Post by: _Nathan_ on June 26, 2011, 03:33:33 pm
When does the weight transfer happen relative to when you want the car to turn?
What are the slip angles of inner and outer wheels during that initial turn in phase? Which wheel needs to describe a tighter radius at this point?
I have spoken to a couple of race engineers that run FWD cars, and both say on a race car they'd be running some tow out for better turn in (one mentioned 4mm out on a modern hot hatch), neither run the golf platform though, I'll read that PDF later.
I believe toe out under bump is pretty common, certainly seems to be the case for a lot of McPherson strut cars, that is what happens on my car too and we still run static toe out along with 4.25 degrees of camber, perfectly even tyre wear, 4 hours from a set of tyres which is on the money.
Maybe the above isn't valid due to the fact that race cars will have less weight transfer so the static values must be higher?
PS. Milliken & Milliken suggests adding toe out as you add negative camber, appreciate this is biased towards performance and not tyre wear but still interesting.
PPS. Thanks for the info, not disagreeing with you as I have no experience of the Golf platform on track, just trying to understand, last FWD car I used on track was years and years ago and was running race suspension and slicks so trying to get my head around setting up a softer car is interesting for me :)
Post by: the bruce on June 26, 2011, 07:17:33 pm
A change of weight distribution does happen in the moment you start
turning the steering wheel. Something very similar does happen when
you hit the brake pedal.
No doubt - maximum G requires different slip angles outer and inner
wheel.
I don't know why they align toe out. I just wonder why they do so.
Maybe the individual steering kinematics is the key point.
Just try both on your own - toe in and toe out - and you'll know more.
In case of us non-professionals it may be way a question of taste.
Post by: _Nathan_ on August 10, 2011, 05:10:03 pm
Page 25 of this months Race Car Engineering magazine confirms my thoughts and gives the reasons why.  :happy2:
Post by: rex on August 12, 2011, 01:36:02 pm
Meaning that the information presented above is correct?
Post by: the bruce on August 12, 2011, 07:02:06 pm
Would like to have a view on that page.  :smiley:
Post by: _Nathan_ on August 12, 2011, 10:18:07 pm
It was in answer to a question regarding why the popular wisdom of toe out for turn in is correct, was answered by a chassis consultant specialising in handing and chassis set up, I typed the answer out for you:
"Cars do generally exhibit quicker initial turn in with static toe out. My analysis is that this does not have to do with the lateral (y axis, per SAE convention) forces from the front tyres, but rather the longitudinal (x axis) forces, which can produce yaw moments.
When a car is running straight, and the front tyres have either toe in or toe out, the tyres are both running at a slight slip angle, and accordingly generating both some lateral forces and some drag forces. The drag forces are roughly equal and additive. The lateral forces are roughly equal, and opposite in direction, so they approximately cancel.
When the steering wheel is turned just a tiny bit, one front wheel will be running straight, the other will be turned in to the corner, generating a bit of drag, and some lateral force in to the corner.
If the car has toe in, it will be the inside front wheel that's running straight, and the outside one that has some slip angle. In this condition, the lateral force creates a yaw moment into the turn, but the drag force creates a yaw moment out of the turn. The two yaw moment components are subtractive.
If the car has toe out, it will be the outside front wheel that's running straight, and the inside one that's making lateral force and drag force. Now the lateral and drag force both create yaw moments into the corner, and are additive. Consequently, the net yaw moment is greater, and the car experiences a greater yaw acceleration. That is it turns in quicker. "
It is a good magazine, I suspect you'd like it.
www.racecar-engineering.com
Post by: Tfsi_Mike on August 12, 2011, 11:05:51 pm
I've nearly posted querying best fast road alignment a few times but it gets super technical super fast.  :sad1:
Post by: the bruce on August 12, 2011, 11:49:27 pm
Thank you, Nathan.  :happy2:
I understand the argumentation, but I guess you understood the
one I posted before.
Drag and yaw components will be present, but weight distribution
will be as well.
So toe out is causing some amount of delay in the first moment.
The race engineer I asked prefered toe in and VW Racing did so
on Laurent's car.
I guess if you ask 10 engineers you'll get 11 answers. Both have
(pretty good) arguements and the rest is a questions of personal
preferences, at least on our kind or cars.
Post by: _Nathan_ on August 13, 2011, 09:53:54 am
Be interesting to see why these people are going against popular wisdom though, every text book I have ever seen suggest toe out.
Maybe the books are all talking about proper race cars rather than soft road cars, or maybe it is just a case that VWR think toe out on a track car that is also used on the road is too nervous on the road (and to be honest it would be a nightmare with following road cambers etc).
When my CSL was a road car with aftermarket suspension (Intrax so adjustable top mounts) I had it set up for parellel toe on the road but a quirk of the BMW is that the chassis slots in which the top mounts are secures are approx 1 degree from inside to outside so with the car in the road it'd be fine running parellel and 2 degrees negative camber but get to the track loosen 5 bolts each side, push the top mount inwards are far as it would go and you ended up with circa 3 degrees camber and toe out, after the day move the top mount as far out as it would go to get back to your original road settings. That is a case in point of track settings that would be horrible on the road and give uneven tyre wear yet on the track tyre wear was perfect and turn in was brilliant.
In summery perhaps everyone needs 2 cars, one set up for road and one for track  :grin: :grin: :grin:
Post by: rich83 on August 13, 2011, 10:00:35 am
Can a little toeout on the front make up for the slow steering rack?
Post by: Tfsi_Mike on August 13, 2011, 10:03:07 am
Ever hear of mkIV racks been used as the response is quicker?
Post by: the bruce on November 04, 2011, 01:18:22 pm
Fuscobal has good results with the Mk.VI steering rack.
Electro-mechanic as well but solid mount instead of rubber on Mk.V.
Steering rack of Seat Leon Supercopa may fit as well, but hydraulic
instead of electric and so an additional pump is needed.
I will give the Whiteline steering rack mount a try.  :wink:
Post by: the bruce on November 04, 2011, 01:34:01 pm
Post by: dionet on February 14, 2012, 01:26:33 am
I don't know if this information is any good, but i have done quite a bit of karting, and on a wet track we have always run WAY more toe out, than in dry conditions, this really sharpens the turn in..
In wet we would run 5-6mm toe out each side :surprised: And in dry about 0,5 mm each side, but when you sit in the kart it will flex, so it would likely be around 0, or a little toe in..
Just thought i would share this :smiley:
