All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: cuprak1 on June 30, 2010, 03:11:54 pm
when the car is on idle, timing was correct...
when I rev it, it tries to correct the timing advance to come back to zero, and it was not doing so.
Any ideas what could be causing this?
Should i just change the revo settings using the SPS+ and see if that helps?
getting a few misfires again even on stock mode :(
Needs logging. :happy2:
boo :( well its going into AMD on sat, lets see what they find :confused:
My complete knowledge lacking guess is coil packs. :happy2:
yeah thats what i bought in the 1st instance but they turned up squashed in the post! what a bugger.
timing will try and return to zero on lifting the throttle, its normal.
what i mean is that it doesnt ever get back to zero
All sorted just had the settings put back on for stage 2+ and changed oil, filters, coils and plugs and its running like a dream. part from the 3rd gear wheel spins we are ok
