All Things Mk5 => Mk5 General Area => Topic started by: PDT on July 20, 2010, 03:29:11 pm
Title: Finally got a chance to finish the mapping on my car... dyno results
Post by: PDT on July 20, 2010, 03:29:11 pm
On sunday I finally got a chance to finish setting up the ED30 with some road datalogging and dyno testing we ended up with:
Boost:8
Timing:8
Fuel:5
Mods are:
Milltek full turboback 3" decat resonated system
Dbilas/pipercross DIY intake
Autotech fuel pump
DSG stage 2 REVO
Forge Twintercooler
REVO stage 2+ software
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Famyhedley1%2Fcar_stuff%2FIMG_0116.jpg&hash=87a27bbf082e404837d94c2acacbdff31185a9d9)
(photo missed the dyno calculations at the bottom which were: Intake temp: 37 ambient temp 23 Barometric pressure 1013 humidity 45)
The addition of the twintercooler allowed us to take timing from 5 to 8 which took the car from 357bhp to the figure you see above, however torque has dropped from 380 ft/lb as we had to lower boost from 9 to 8
Title: Re: Finally got a chance to finish the mapping on my car... dyno results
Post by: cuprak1 on July 20, 2010, 04:22:32 pm
Looking good mate :)  :congrats:
Post by: Andy on July 20, 2010, 05:13:55 pm
Looking good Dave :happy2:
Post by: Janner_Sy on July 20, 2010, 05:52:51 pm
awesome figures for DD rollers. How come the curves are so condensed, is it possible to spread them over the complete width of the graph, its better to compare the curves with others then.
the new dyno graph thread here as well :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,16977.0.html
would look better if you could get the torque an power figures on each side of the graph the same
Post by: Hurdy on July 20, 2010, 05:58:18 pm
Timing 8 OMG, were you on normal 99 ron or race fuel?
Did you get any logs done?
Good result on the run :happy2:
Post by: PDT on July 21, 2010, 12:24:25 pm
I can adjust the scale of the graph but this is how we set up the screen for all dyno tests.
Hurdy, this was using 'normal' 99 octane fuel, the twintercooler really helps keep intake temps really low, we saw a timing pull figure of 4 degress after a few 4th gear pulls but intake temps were still at just 34 degrees.  On the dyno this raised to 5 degrees of pull and an intake temp of 43 degrees after 3 dyno pulls at WOT.
Post by: Janner_Sy on July 21, 2010, 05:04:49 pm
:happy2: :happy2:
throw it in the new dyno thread :happy2:
Post by: bacillus on July 21, 2010, 05:35:33 pm
The rpm scale is not shown so could you state @what rpm do you see your max hp at.
Post by: Tara on July 21, 2010, 06:08:27 pm
Looking good! :happy2:
Post by: theo on July 21, 2010, 06:12:05 pm
Interesting results dave. Looking forward to getting mine dyno'd now and seeing what results it gives!
Post by: Sunglasses Ron on July 21, 2010, 06:19:48 pm
Awesome results mate. Looking forward to seeing what mine will make on DD rollers on Sat (same mods, just without the the cooler and standard Dbilas). Although it aint going to be as high as that even though I have the same mods, just without the the cooler and standard Dbilas (not hybrid).
I will however be running early in the morning so that should help as the temps on sat according to the weather should only top 18oC. Just unsure what settings to run, as I don't have VAGCOM  :sad1:
Any ideas?
Post by: Poppa Dom on July 21, 2010, 07:05:19 pm
Are you stage 2+ Ben? Go for b8t5f6 if you are as a baseline.
Post by: Sunglasses Ron on July 21, 2010, 07:08:18 pm
That's exactly what I am at the min mate and seems pretty good. Just don't boot it much when it gets silly hot outside (like 25+ on temp gauge).
Post by: gazbutS3 on July 21, 2010, 07:47:02 pm
I'm running that also B8 T5 F6, and have logged it and its all pretty good as shown by the results at the Halifax RR day :happy2:
Post by: Janner_Sy on July 21, 2010, 07:49:04 pm
gaz, post your graph up in that thread, and then if PDT can change the scales on his graph we could make a good comparison between the two.  iirc yours was similar at the last RR day??
Post by: gazbutS3 on July 21, 2010, 07:53:13 pm
will do after dinner pal
Post by: Janner_Sy on July 21, 2010, 07:55:21 pm
dinner at this time of day.  never, you must be about o have tea, because dinnertime is at midday :grin: :laugh:
ill just get my coat  :sad1:
Sy :grin: :happy2:
Post by: PDT on July 21, 2010, 08:23:41 pm
Any ideas?
As for the temps on the day, it wont really affect things as the Dyno (all dyno dynamics will have) has a weather station so it will forward/back calibrate the results so the weather on the day wont affect the final result.
i.e if its an extremely hot day the dyno will add to the compensation figure that determines the losses due to increased temps. On a cold day the dyno will do the opposite and take power off the actual figure. This way if you have a car that you get on the dyno quite often (we get customers that ask us to map their car at the beginning and the end of a season which is ofen a difference of temps of around 30 degrees ambient temps) it will still make the same power regardless of the weather conditions. this way it removes the variables and allows you to concentrate on  facts as you are mapping / testing
Post by: Janner_Sy on July 21, 2010, 08:25:56 pm
it makes a different when runnin the std cooler though, mine suffers heatsoak on the dyno in this weather, but is ok if i do it when its cold
Post by: Sunglasses Ron on July 21, 2010, 08:30:35 pm
That's more where my problem may lie Sy. But very interesting about the DD rollers and the weather variences, clever stuff that. :wink:
Post by: 94Luke on July 21, 2010, 09:17:36 pm
Any ideas?
That's a pretty nifty feature, not heard about that one before. So what temperature is it calibrated to where it doesn't compensate at all?
Post by: PDT on July 21, 2010, 10:47:52 pm
its not just temperature that you take into account, its also humidity, barometric pressure, intake air temperature etc..... so determining the absolute temperature that they zero calibrate at isnt as simple as it seems.
If your car starts to heatsoak on the dyno then the dyno needs better cooling, ideally a dyno run should match as closely as possible to a road run in both intake temps and pull time, but most dont. We spenat ages testing different fans and even though we now have an OK setup it still isnt ideal, so I have now invested in 2 more fans that are capable of this:
I predict a few number plates going on a journey  :signLOL:
Post by: 94Luke on July 23, 2010, 02:45:21 pm
Haha that looks like a very powerful fan. Do they do fans that mimic airspeed as the speed of the wheels increases? Like the wheels doing 70mph the fan is blowing 70mph? Always thought that would the most accurate way of seeing what power the car is making as it is moving along.
