All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Gtiain on July 28, 2010, 08:49:23 pm
Title: Climate control on rns-510?
Post by: Gtiain on July 28, 2010, 08:49:23 pm
Hi guys. I've seen pics of the rns-510 with pictures of seats on and what look like climate controls? How do you get this on?
Title: Re: Climate control on rns-510?
Post by: vRS Carl on July 28, 2010, 08:50:11 pm
You need the latest Climate Control panel from a MK6 Golf or new Passat etc :happy2:
Post by: cameluk on July 28, 2010, 08:54:32 pm
And mods to the climate control motors, central electrics and possibly add the air quality sensor  :scared:
Post by: Gtiain on July 28, 2010, 08:57:54 pm
Right I see that sounds like a lot of effort! Just out of interest can this panel be retro-fit on a mk5?
Post by: vRS Carl on July 28, 2010, 09:00:53 pm
It's a straight swap of the panel but you need Dual Zone to start with
If not and you have the normal Climatic Air Con your looking at over £4k for a conversion as this is what you would need:
New Compressor to take into account the difference in fan speed
New Fans - yours has 4 speed and the dual zone is about 9 from memory
New Wiring Loom - To control everything
New Control Unit - on the dash.
New AirCon Control Module - to account for differences
New Vents - Yours are controlled by cable and the Dual Zone are motorised
New Air Quality Sensor - You have a diff one installed
Then labour on top which would be a long time as the whole dash needs to come out
All very expensive
Post by: Gtiain on July 28, 2010, 09:43:03 pm
4k!!! Wow. I have got dual climate control but that is an incredible amount. Thanks.
Post by: vRS Carl on July 28, 2010, 10:09:54 pm
If you already have Dual Zone then it's about £160 on eBay for the dash panel and thats all you need  :happy2:
Post by: Gtiain on July 28, 2010, 10:21:24 pm
That figure might be a bit more realistic! I can't get over that figure of 4k! Thanks.
Post by: golfman on July 28, 2010, 10:42:57 pm
Ive been wanting to do this for ages but just dont know whats involved!!!
carl are you sure its just £160?what parts are required?
scott
Post by: vRS Carl on July 28, 2010, 11:16:48 pm
You need Dual Zone Climate control in the car already. If you don't have this then it is too costly to do.
Then you need this panel
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fes.volkswagen.com%2Fetc%2Fmedialib%2Fvwcms%2Fvirtualmaster%2Fes%2Fmodelos%2Fpassat_cc.Par.0049.Image.jpg&hash=5c73286c91d1bde97084b481e13c1f121bae0c2c)
Which is from the Passat CC. You may also need a new Central Elec Control Module BUT i'm fairly certain everything needed is contained within the panel.
I know of a couple of people who have done this but it has been in Octavia's. One of those panels was on eBay recently for £160
Part no. is 5K0 907 044 BD ZJU which is for a Satin Black one. From a dealer they are around the £300 mark.
You may also need a new Can-Gateway depending on your car as the earliest anyone i know to have this working is at least an S revision
You will also need a new MFD3 Surround or you could do this (which incidentally is on a MK5 2007 Golf)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg248.imageshack.us%2Fimg248%2F1071%2F01082008007.jpg&hash=f25851a35c694d1a06ebd467009c6976b7c81740)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg248.imageshack.us%2Fimg248%2F8456%2F01082008006.jpg&hash=7213ca20196f81b8d67cf40f191480194ddbbac1)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg248.imageshack.us%2Fimg248%2F136%2F01082008004.jpg&hash=c16c60a66e4c544dac5d273d4fa7c5af9b44b8e5)
You may find 5K0 907 044 AK ZJU versions on Ebay in which the only difference is a slight change on heater buttons
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimages.forum-auto.com%2Fmesimages%2F353265%2FRedimensionnement%2520de%2520cimg5194-35803.jpg&hash=58995bd84d41abe14200e21591e3cdc956114ddd)
Post by: vRStu on July 29, 2010, 08:02:29 am
You'd definitely need the new fascia panel, that chopped up one looks naff.
Post by: 182_blue on July 29, 2010, 08:40:26 am
It is a trick feature but im not sure its worth the hassle for getting pic on screen alone, although the switches do look better too
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi2.photobucket.com%2Falbums%2Fy8%2F182_blue%2FIMG_1148.jpg&hash=f4299ad170896f0197b721ed57fa466ab7e4ec44)
Post by: Richn83 on July 29, 2010, 09:32:58 am
The surrond from the current Jetta is designed for the new aircon controls and the MK5 dash, so you should be able to get hold of one of those parts, last time I looked at this the consensus seemed to be that you would need to convert the whole system over to the BAP protocol, is this not the case?
http://www.mk5golfgti.co.uk/forum/index.php/topic,13273.0.html (http://www.mk5golfgti.co.uk/forum/index.php/topic,13273.0.html)
Post by: xxx_mojo_xxx on July 29, 2010, 10:57:37 am
 :popcornsoda:
Post by: danishmkvgti on July 29, 2010, 11:31:00 am
 :popcornsoda:
Post by: vRS Carl on July 29, 2010, 11:36:49 am
Not heard of anyone having to change everything to BAP. But as I said I only know of a couple of people doing it in Octavias.
From what I gather it is a straight swap of the panel. A bit of coding and job done. Maybe a new Gateway depending on how old it is.
There was some talk of pins needing to swapped on the connectors but not had any confirmation of this.
Post by: Richn83 on July 29, 2010, 11:39:12 am
Hmmm Interesting Carl, do you have any links to threads?
Post by: cameluk on July 29, 2010, 03:31:08 pm
Massive thread over at vwnavi, which goes round in circles and switches between Skoda and VW at a drop of a hat, and doesn't really confirm that everything works on a Golf  :chicken:
http://vwnavi.com/showthread.php/9170-Climatronic-on-screen (http://vwnavi.com/showthread.php/9170-Climatronic-on-screen)
post #336 looks the most interesting  :confused:
Post by: Richn83 on July 29, 2010, 03:40:48 pm
That does seem rather alot of work for the rewards, but good to know its possible!
Post by: golfman on July 30, 2010, 02:53:16 pm
carl i already have dual zone climate control in my 06 car!!!
so what else are we talking?
scott
Post by: vRS Carl on July 30, 2010, 04:35:31 pm
The Dash Panel and maybe a Can Gateway due to it being an 06 Car.
As far as I know nothing else. Like I said though I only know of a couple of people doing it  :smiley:
Post by: golfman on July 31, 2010, 10:30:13 am
carl this is my can gateway!!!
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K0940304CC
   Coding: E9817F16400602000003
   Shop #: WSC 00787 210 95039
   VCID: 3753F89B3F25
No fault code found.
im sure ive heard something also about joining wires from other things also?
scott :happy2:
Post by: vRS Carl on July 31, 2010, 10:34:06 am
You have an S version so should be fine.
Not heard about joing wires but swapping them on one of the connectors. There is a link on this thread to the thread on VWNavi where people have done it. One guy (LALA30) i think put the diagram on for the wires. I have not had any confirmation of this.
Im not saying this will defo work but all i have heard anyone doing is putting that panel in, bit of coding & job done :happy2:
