All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Gtiain on August 02, 2010, 12:02:29 pm
Title: Watching a DVD on rns510
Post by: Gtiain on August 02, 2010, 12:02:29 pm
Hi Guys. Say if I'm watching a DVD while waiting for somebody I usually leave the engine running as I'm paranoid the rns will drain the battery fairly rapidly, am I right to think this? I wondered if there was a mechanism if say I just had the ignition on were the rns would turn off if the battery was running low? Thanks for your help.
Title: Re: Watching a DVD on rns510
Post by: 182_blue on August 02, 2010, 12:10:42 pm
The Rns does indeed turn itself of when it thinks the batter has had enough, I used to get it all the time when trying to update the firmware on my old one, I'm not sure what happens with ignition on so best to leave it off
Post by: Britishlion on August 02, 2010, 12:11:07 pm
I currently have battery drain (separate issue) and if i have the rns on without ignition it shuts down and says
battery to low for stereo use !
Post by: Gtiain on August 02, 2010, 12:15:35 pm
That's annoying for you. You'll have to get a new can bus as I'm sure your aware.
Post by: Britishlion on August 02, 2010, 12:17:04 pm
I have got one ! but typical me
bought MFSW buttons and cruise control to fit at the same time !
Then over to Darren for heeelllllppppp !!!!!
Post by: Gtiain on August 02, 2010, 12:26:23 pm
Yep darrens the man, he fit my rns510 and reversing camera on my mk5 running 1100f/w and they work perfectly. No battery drain.    :happy2:
Post by: Britishlion on August 02, 2010, 12:29:12 pm
Thats cus your on 1100
Typical me !
Buy LED C version running 2680 stick it in (worry about battery drain later)
And now have car sat in driveway (battery goes dead over four days !)
But fingers crossed i will be over to darren later in the week and problem solved ! plus new toys !
sorry to go off topic but yes the RNS  will tell you when it is using to much !
clever kit
Post by: Gtiain on August 02, 2010, 01:07:41 pm
Thats good then thanks. You should consider the rvc it's fantastic and Darren can fit that aswell.
Post by: Britishlion on August 02, 2010, 01:09:28 pm
My bank account is drained !
For this month anyway !
My next two MODS are Camera and Bluetooth !
 :grin: :grin: :grin:
Post by: Gtiain on August 02, 2010, 01:21:54 pm
Same here! Bluetooth for me next then xenons with auto leveling then led rear lights then 18" monza 2s. So quite a big list! I'm skint too, wish I had the money to do it all in one go!  :happy2:
