All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: cameluk on August 03, 2010, 08:45:31 pm
Title: RNS 510 Lost Fader Control
Post by: cameluk on August 03, 2010, 08:45:31 pm
After fitting my Blaupunkt THA 555 PNP amplifier with the PnP harness, I have lost the option under Tone of Balance / Fader with the fancy in-car graphic, I only have balance for left/right
I disabled speaker monitoring in Byte 4 setting it to either 00 Not Coded or 01 Speaker Monitoring InActive as I ended up with a huge list of fault codes as the RNS could no longer detect the speakers being attached due to the Amp I think
Is there any way of being able to control the fade from the RNS between front and rear now that I have an amp  :confused:
