All Things Mk5 => Mk5 General Area => Topic started by: gobbleplease on August 05, 2010, 11:29:55 pm
Is there anything else that can be done to reduce it ? i know the an LSD will help, i didnt want to spend that much though Ta
Current set up below
Drive slower? :P
Ill get my coat....... :laugh:
White line anti lift kit £160 made the biggest difference for me!
EDIT
just re read your massive list of mods... ill get my coat :sad1:
if you have understeer with your mods, you need the rear arb set harder or get a stiffer rear arb. also stickier tyres would help :happy2:
if your car is still understeering alot even with all your mods, id have to say its your driving. all front wheel drive cars will suffer with power understeer if your to aggressive on the loud pedal during cornering.
i had eibach ARBs on mine. i found that with the rearbar on its stiffest setting and the front on its softest that understeer was at its lowest. never really had an understeer problem
if i was to do it again i would fit an even stiffer rear bar because i like a loose back end, with a more oversteer bias.
you could look into a BSH 27mm rear ARB and flog your eibach rear bar. however you start to lose independance of the suspension by having such thick bars on the car.
a better alternative by a long way would be the TT lower control arms, the extra 0.5o neg camber will massively increase cornering grip. thats only about £400 fitted
I set the rear to fully hard a couple of weeks ago and it made a big differance.
Tyres will deffo be soon, down to my last 3-4 mm on the front.
Seen a nice set of of toyos in the fs section. Mmmmmmmm !
If the weather is good on Tuesday I think I'm going to knockhill, the only thing is I've just broke two fingers so I'll need to see how they feel first, so I was looking for something quick ish to try.
I'm going to chuck on my pagid blues to see how they are
Can you dial in more camber on the gti cheaply eg with out buying adjuster plates for the coilovers or s3 arms
:smiley:
cheers guys I think slot of the understeer is due to the fact my front tyres are crap !
Got to say I expected the rear bar on hard to be very oversteery but it's still very neutral
On sh1t, forgot to say will I need alignment done again now that the rear arb has been adjusted
Nope.
Whiteline do an adjustable topmount, but I'd prefer camber via a longer wishbone. Get your geo track biased too, that helps lots.
front camber and castor is fixed.
you have 3 options of changing the camber.
tt lower arms,
morego power grip lower arms
top mounts (KW or whiteline)
tt lower arms,
KW only fits clubsport diameter springs, and they are a lot smaller than stock. :stupid:
