All Things Mk5 => How to Guides / Troubleshooting => Topic started by: 182_blue on January 31, 2009, 11:54:35 am
I just thought i would post a little guide of how to fit the Passat parts with extra chrome bits , it may also help those who wish to fix faulty parts too, i bought the set from eBay and used the panel tools that i have had a while, if you require any help just ask (ps i accept no responsibility if you damage anything whilst dismantling your own car)
The tools i use
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0145.jpg&hash=4fb2d3fcfb8d7fc75f614d157a6f631e6d92e3af)
The parts
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0182.jpg&hash=3a23e1c4d828d200dbb56ea284d19da5d7bac273)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0186.jpg&hash=cb515a5bc42d74cc6e7428f4d6569d8305e98bcf)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0185.jpg&hash=ed8a1b8fa381d1c56d85fd5dc8e923e37b0797dd)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0184.jpg&hash=5bc4640ba335622e0b479615abb273b88d626dae)
Light switch,
use this guide (as posted by Very Cherry)
– Switch off ignition and all electrical consumers.
– Turn rotary grip of light switch to position “0â€Â.
– Push in rotary grip of light switch -1- and turn it clockwise slightly -2-.
– Hold grip in this position and pull light switch out of dash panel using grip -3-.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FRepair_Manuals%2FHeadlight_Switch%2Fheadswitch1.jpg&hash=26d808ff553bb3fced380eb11f71ae4142bbe7a3)
Disconnect connector -arrow-
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FRepair_Manuals%2FHeadlight_Switch%2Fheadswitch2.jpg&hash=9b84e6953c920a9e210494243d9183b107baef50)
Installing
– Fit connector to light switch. (as above)
– Hold light switch and press rotary part of light switch firmly inwards -1- and turn slightly to right -2-.
– Hold grip in this position and insert light switch in dash panel -3-.
– Turn grip of light switch to position “0â€Â, release and engage switch.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FRepair_Manuals%2FHeadlight_Switch%2Fheadswitch3.jpg&hash=458151020b63ee7f4c31c3737b0ee9a6789e0b98)
simple really, just hope it isnt locked in like mine was, then simply remove the plug and put new one in and slide it into place
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0131.jpg&hash=b9b99395080389fcb5e3ddeab2695720b116a4e1)
Drivers handle
I pulled it from the front, you will see the two clips on the right hand side, when these are free you will then need to free the two metal clips at the bottom of the handle near the back, these are a little harder to remove but a little pressure and they come out, dont pull to hard as the handle is held in by 3 plastic pop in bits, again gentle pressure and they soon come out, then its simply removing the old switches by pushing a flat blade under the clips and the old electric unit pops out, pull out electrics and instal new unit, then re fit electrics and pop handle back on
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0133.jpg&hash=92bc8379004265530597c783ba9f2791c15ea6a3)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0146.jpg&hash=2c4bcb01d7c7413c93a9d91dbad5fbeb4f09977b)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0147.jpg&hash=5024163a80086ac2e8628a5e945efa11ef39fcb4)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0148.jpg&hash=907a926eebefb60e094b092d39d500c5853c3f25)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0149.jpg&hash=a647c86f1e4d0acf0e61aaec41d898ea2199cce1)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0189.jpg&hash=d418e7ae30f63bbb3e0176298e15965c41aef828)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0190.jpg&hash=be602b9382a8720c184713a6db4186ad2f4a8517)
passengers handle
For these you remove the bottom part of the handle, start at the back of the handle (as in picture), and pop the handle out, the handle is then held in via two metal clips and a plastic pop clip right at the top, the handle pulls directly out from the door, do not pull up or down etc, just pull it directly outwards , then you can see the switch, i again removed the switch by prying it out with a flat device, when out pop off electrics put in new unit, put electrics back in and renistall the unit, handle pops back on and jobs done (well, after you do the other two handles)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0134.jpg&hash=a684ed0bd21514043b9f9e15951eba49a2a68fe0)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0151.jpg&hash=cf5e986c10d1c71cfa90a23f47f606a09fdff45c)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0153.jpg&hash=03023a9f3c17a434f301ce4af646b9aa85754948)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0152.jpg&hash=8fd9c44c06228f94bfae7bf8ee2bd32ebf6b88e0)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0157.jpg&hash=1e03f3545538dd7c943c19b3fc5fa393ae7361f8)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0156.jpg&hash=43fe82b9b6a32192688eb9e464f7553445324043)
And all done
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0191.jpg&hash=86d9caba6ce69db0fc5e50b82f75d2bf8a6ddba2)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0195.jpg&hash=0fa21220ee329744f2a2c539590669e97dbcf1b1)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0196.jpg&hash=8260d907cd4acfdec9a126b9ef4d5a35863eef35)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs99%2Fblue_182%2FIMG_0198.jpg&hash=82db35cfacd23ddf174bea8f00e5ba20a3915d76)
very thorough Shaun Excellent stuff. :drinking:
Nice one Shaun :happy2:
I take it mine will be a bit cheaper as mine is a three door?
Can you PM me the E-bay seller details please mate?
I should have all the technical drawings for the removal of the other bits if you want me to post them up?
yeh, why not :happy2:
Here you go mate:
Removing and installing switch module for driver side window lift
Special tools and workshop equipment required
- Removal wedge -VAS 3409-
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FRepair_Manuals%2FDoor_Handles_for_Switches%2F001.gif&hash=be8a318de4303997a9c87953da9a59bab9b0469e)
NoteWhen removing and installing components that are in view (switches, covers, trim and so on), mask off areas in which tools (wedge -VAS 3409-, screwdriver) are used to prise out those components using commercially available adhesive tape.
The following components are integrated into the driver side window lifter switch module on 4-door vehicles:
- Front left window regulator switch -E40-
- Rear left window regulator switch in driver door -E53-
- Rear right window regulator switch in driver door -E55-
- Front right window regulator switch in driver door -E81-
- Childproof lock button -E318-
- Button illumination bulb -L76-
Note The above mentioned components cannot be replaced individually.
The following components are integrated into the driver side window lifter switch module on 2-door vehicles:
Removing
– Use the removal wedge -VAS 3409- or a screwdriver to carefully prise the mounting frame out of the door trim -arrow-.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FRepair_Manuals%2FDoor_Handles_for_Switches%2F002.gif&hash=a1c71eec289e1386df9d8e998def9d7c859b1ed8)
– Separate connectors -arrows-.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FRepair_Manuals%2FDoor_Handles_for_Switches%2F003.gif&hash=0e2c6b1c63247a4e3855fa495d1323a41b2cf9a8)
– Release locking lugs -arrows- and remove switch from installation frame.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FRepair_Manuals%2FDoor_Handles_for_Switches%2F004.gif&hash=de6f3c219fd33da2b73f9d6a528b00842078058a)
Installing
Install in reverse order of removal.
Removing and installing fuel tank flap release button -E319-
NoteThe fuel tank flap release button -E319- features integral button illumination -L76-, which must not be replaced individually.
Removing
– Remove door trim → Rep. Gr.70.
– Disconnect connector -arrow-.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FRepair_Manuals%2FDoor_Handles_for_Switches%2F005.gif&hash=34a88c848e71d1cfa0197943611e709ae4c7290e)
– Release locking lugs -arrows- and remove switch from door trim.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FRepair_Manuals%2FDoor_Handles_for_Switches%2F006.gif&hash=3b6b58fdcf9cb4cdba157892a1a0b3d7e3183498)
Installing
Ahh, So it's a door panel off job :sad:
Afraid so by the looks of things, and yes...theres a guide for that too lol :grin:
tbh i think maybe leave the switch standard, your eye doesnt need to be drawn to it and you'll never really see it anyway
although it could bug you
Nice guide!
Thank for taking the time to do it :smiley: :smiley:
great right up shaun, and regards the bojo tools, there great. had a set for ages and they havent changed, bent, degraded in anyway. an absolute must for anybody doin any interior work.
I like the Light switch - same as the new Scirocco as well. Nice guide too..
Nice write up.
Where'd you get the removal tools from?
They are available on ebay. I think I just searched for trim removal tools.
Like this. http://cgi.ebay.co.uk/Sykes-Pickavant-5-Piece-Trim-Removal-Tool-Kit_W0QQitemZ390027833345QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item390027833345&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318
I have those type, pretty handy.
Extremely good guide and crystal clear pics.
But personally I'd be wanting to swop any silvery bits to plain versions! But ETTO :happy2:
Hi 182_blue iv'e ordered these parts can you tel lme how long it took to get them?and did you get a DHL tracking number from them?
cheers golfman!!!
Hats off to you Mr 182_blue. Just done this with help from your guide. :happy2:
Been a busy boy then Mr H.
All this time you spend on your own car means I've just had to wash and wax mine myself!!
good good, you happy with them ?, look alot better imo
I would have to agree. :wink:
One day I'll let you do mine if your lucky. Keep practicing. :P
Just fitted these today very smart upgrade definitely worth doing!!!
cheers 182_blue :happy2:
I can see that their addition helps the brushed ali trim which is already there and which I think looks a bit solitary ex-factory.
I like those! The devil's in the detail as they say :happy2:
Any chance you could PM me the seller details from ebay please Shaun? :smiley:
I've been thinking that the petrol cap release is looking a bit left out.
I understand that the Passat includes the boot release with the petrol cap. I was just wondering if you could fit the top part of the petrol cap switch to one of the single window lifter switches that you have left and use that.
Any thoughts?
noticed this light switch is fitted in the new mk6 golf too.
38notes plus the vat from dealers no uk stock at the mo.
Any thoughts?
im confused ?, why would i want to put it on a window switch ?, i could just buy the passat switch and try and de construct it and see if it fits on the golf cap release, but the parts is about £20 + for something i hardly ever see
heres the passat one marked 7 note its a double switch
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy183%2F182blue%2Ffdfdf.jpg&hash=538614711f7a6b27c6d97bfa6ec06b60193cb143)
Thanks for that. I had come to the same conclusion myself and was planning to buy the original Golf one and the double Passat one just in case I make a hash of things.
The reason I was thinking to use the window switch was that I have 3 spares. :ashamed:
the golf one looks quite a bit different, but i think the cap may just be the same (ps the caps do just pop off, i tried)
its part number 3 here
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi5.photobucket.com%2Falbums%2Fy183%2F182blue%2Fs.jpg&hash=293aaad90bc0f0d41a97f5222a9e10743916a135)
Sorry to lift an old thread, but I'm after a set of silver trimmed switches but can only find them from oemplus.com. Their prices are fair enough prices but the shipping is going to be £60!
Does anyone supply these in the UK?
Cheers,
Andy
You could always get them from a VW dealer. :wink:
Certainly a last resort, yes, but knowing the prices they charge for everything else I don't suppose they're the best value either!
Small snag when speaking to the dealer, they need me to work out the part numbers, lazy sods.
Does anyone have ETKA and can tell me the part numbers for the silver trimmed drivers side switches (for a 5 door), passenger side switch, headlight switch and mirror control please?
If not I guess I'll just have to find a hooky version of ETKA off the net.....
Cheers!
Are these a possible fit to the 3dr? Can just the switches alone be changed, rather than the whole control panel?
Perphaps Scirocco or Mk 6 ones will fit?
you can actually dismantle them and put the new rocker part (with silver trim) on your old ones :happy2:
Can anyone supply all the part numbers, ideally for a three door?
Need to start writing my letter to Santa! :laugh:
Not sure if you can do a 3-door as the switches I bought came from a Passat CC.
It may be possible now as the Mk6 has the same switches.
Yes that's exactly what I'm after. Doesn't matter if it's a Passat or MK6 Golf part number, as long as they're chromed! :happy2:
Well I don't have ETKA but why not speak to your local dealer.
I want to go ahead and get these although getting the p/n's and prices is a real pain. MY local dealer is not interested in helping just says there are too many variations of switches to search through.
182 Blue can you PM me the sellers details and an idea of price.
Anyone else got the p/n's yet???
Here you are rob this is where i got mine from after 182blue's help :happy2:
http://cgi.ebay.co.uk/VW-Fensterheber-Schalter-Paket-chrom-golf-Touran-Passat_W0QQitemZ180325521440QQcmdZViewItemQQptZAutoteile_Zubeh%C3%B6r?hash=item29fc3d1820
scott.
Thanks for that although they seem a little pricey :surprised:
This is the problem, unless we know the Dealers proces we have no idea if its worth buying elsewhere. In my experience eBay prices are no cheaper especially when you include postage.
If anyone whos fitted these can give the part numbers then I can get some VW prices for comparison.
182 Blue / Golfman did you keep the boxes with the p/ns'?
The part numbers were here all the time.
http://www.mk5golfgti.co.uk/forum/index.php?topic=1795.msg29282#msg29282
Hi, how much did all the replacements chrome switches cost including rear ones.
Cheers.
Bit of a thread resurrection here I know but I just got a full set (minus the petrol flap switch) from Bold sport for $90, which I think was a great deal and they only took a week to arrive.
Fitted them yesterday and they look good.
I'd recommend using a feeler gauge or similar to to lease the passenger window switches
I've got the new petrol flap switch to go on (also from Bold sport) but not fitted it yet.
You got a link chap?
I thinks this one http://www.bold-sport.com/store/index.php?route=product/product&product_id=83
Thanks!
Gutted the set for a 3 door is more!! :confused:
Also, i don't seem the different between two sets, except prices. One for 90, another one for 150, seems the same.
Sorry just seen this. I bought the cheap set as I could not see a difference and they are perfect and at only $90 a proper deal (that didn't include the filler cap release)
Fitted the filler flap release now, door card off job but not too tricky.
Thanks for the guide. My rear window switch wasn't working so took it apart. Luckily I had the same tools as the OP, which are great for getting trim pieces off without ruining them. The cable wasn't connected to the switch, but changed the switch anyway and another as I bought some switches off here a couple of weeks ago to change the worn ones.
Are these Bold-sport parts sent from HK?
http://www.mk5golfgti.co.uk/forum/index.php/topic,52040.0.html
They are, but I've bought twice from them. The first time the package didn't turn up but after emailing them they sent another without quibble. I'd use them again.
Got my fuel switch today.Very quick posting all the way from HK :happy2:
Does anyone have the part numbers for the required bits
Does any one no if these will fit a Leon mk2? I only have 2 switches on the drivers door. The add says yes but in the description it doesnt mention it
Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.view&id=181054060155
Sent from my HTC One using Tapatalk 2
Well done! That looks a really sweet mod, makes such a difference :) :happy2:
Hello,
New the the forum, is there any chance in the VW part numbers? :happy2:
Sorry just read through the tread again seen the link :stupid: I take it I can just go to VW and ask for these at the parts Desk?
Cheers Dan
Great guide guys :happy2:
Si
Yep top guide, recently ordered the parts and planning on fitting soon :happy2:
So my switches turned up earlier this week and I had a go fitting them this weekend. Seem to work fine and certainly look nice, but I'm getting a funny error in VCDS now. Anyone had similar?
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Control Module Part Number: 3C0 937 049 E HW: 3C0 937 049 E
Component and/or Version: Bordnetz-SG H37 1002
Software Coding: E58D0F2700041800001400001400000000087F075C
Work Shop Code: WSC 00000 785 00200
Additional Info: 1K2955119C Wischer VW350 013 0402 1K0955559T RegenLichtSens 011 1110
VCID: 2B55C1518AE29934DCA7C3
1 Fault Found:
01800 - Light Switch (E1)
008 -- Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 3
Reset counter: 16
Mileage: 154802 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 16
Mileage: 154802 km
Time Indication: 0
Freeze Frame:
OFF
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
I've cut this from another poster who had the same problem
This could mean a few things,
1. Switch itself is broken, common issue
2. cable isn't connecting or has cut in it.
3a. I pulled out the switch from the dashboard and disconnected the cable and checked connections in switch, which they were all clean and no sign of burnt. Also checked the cabling and no sign of any issues. Placed the cable back into the switch.
3b. Cleared 01800 error and rerun test on VAG.com, no more errors appeared, so I think maybe one of the connections where not making a solid connection from cable to switch pins.
So basically he unplugged then reconnected it finally cancelled the DTCS an no more problem!
Does anyone know how to fit the fuel cap switch?
See reply No 6
http://www.mk5golfgti.co.uk/forum/index.php/topic,1800.0.html
I think it can be done by undoing the screws on the door card and you can reach up behind if your carful. :happy2:
Cheers Stephen, ill give that a read!
Literally 10 seconds ago I just fitted the driver side windows and mirror switch, as well as the door pull handle. Looks great!
Quick question though, on the old mirror switch to have the heat function on you have the switch in the middle. On the new mk6 switch, the middle appears to be a '0'indicating off, and the heat function is at the top, and the switch actually pivots 180 degrees to get there. Will the off position still be the heat function?
Heat function will work OK Mine does As StephenED30 said Undo screws on bottom of door card and reach up inside. Small hands and thin blade :happy2: On the other hand removing the card is no biggy :happy2:
Do I switch it to the 'O' position to turn it on?
Cheers I'll just remove the door card I think :laugh:
Just use the new button like its marks indicate. My mk5 Golf has the same marks as the mk6. Your model is just a bit older. All should work fine. :wink:
I'll just have to test it :smiley:
Just got the fuel switch left to fit now, but it's raining so can't do it at the moment :scared: I'm so impressed with how much of a difference it makes though!
