All Things Mk5 => How to Guides / Troubleshooting => Topic started by: edd666999 on September 02, 2010, 06:08:30 pm
Title: fuel pump leak
Post by: edd666999 on September 02, 2010, 06:08:30 pm
I decided to swap my cam follower today, took the right hand side metal connector off my fuel pump but realised I didn't have the correct M8 spline for the left side, so put the right side back on, put everything back together, opened my drivers door and the left un touched metal pipe started leaking fuel! I have tried tightening the bolts to no effect.
I'm going to get the correct M8 bit tomorrow and take it off, does anyone have any ideas why its pi**ing fuel!
Title: Re: fuel pump leak
Post by: vRS Carl on September 02, 2010, 08:02:46 pm
Apart from something has come loose i can't think why.
Are you sure it's coming from there and not spraying from the one you did remove on to that one.
Post by: bacillus on September 02, 2010, 08:04:44 pm
Opening the driver's door primes the fuel pump hence the leakage.   :smiley:
Post by: vRS Carl on September 02, 2010, 08:08:06 pm
It shouldn't be leaking if it's all put back together. Which is what the OP did before opening the door.
Post by: edd666999 on September 02, 2010, 08:47:22 pm
100% sure, it drips drips drips! it got worse when i tightened it!!!
i just hope that tomorrow when i get the correct bit that i can change the follower, put the pump back together and have no leak...otherwise...new screws? or pump possibly.
do you have access to that program that tells you the part numbers for the pump and all the metal connectors that go into the front of it?
i also fitted a new n75 valve as it was only £20 from dealers and took me 40mins to fit being very carefull.
Post by: vRS Carl on September 02, 2010, 08:51:59 pm
You mean ETKA
Yes give me 5 while i locate it…...
Post by: gazbutS3 on September 02, 2010, 08:56:21 pm
have you crossed the thread of the union???
just a suggestion :smiley:
Post by: bodger00 on September 02, 2010, 08:58:09 pm
Sounds like a real pig! My guess would be overtightening or you have cross threaded the connector.
Careful you don't bend the metal pipes too much when getting thebolt loose. The pipes need to be bent slightly though to remove the pump.
 The connections need to be nipped tight not overtight.
Hard to describe but you should be able to feel it.
Oh and don't be daft enough to drive it whilst leaking fuel :rolleye:
Post by: vRS Carl on September 02, 2010, 08:58:17 pm
What Engine code and model year are you? AXX 2006 isn't it?
Post by: vRS Carl on September 02, 2010, 09:04:50 pm
Does this help you?
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fww275%2FTaufe%2FScreenshot2010-09-02at205857.png&hash=70b303714f235500998f307cc84504dd8c9beac0)
Post by: edd666999 on September 02, 2010, 09:05:09 pm
yea
Post by: edd666999 on September 02, 2010, 09:06:32 pm
Does this help you?
from that picture i get the idea that that has 1 metal and 1 rubber pipe not the 2metal i have...
Post by: edd666999 on September 02, 2010, 09:07:38 pm
it was real difficult to leave my car at my mates garage but i thought...do i was to be driving a flame ball on wheels?
Post by: vRS Carl on September 02, 2010, 09:08:23 pm
Hang on i'll get you the other pump then
Post by: edd666999 on September 02, 2010, 09:08:29 pm
this is what im thinking...and by taking it off fully it will all work itsself out!
Post by: edd666999 on September 02, 2010, 09:08:51 pm
:signLOL: thanks!
Post by: vRS Carl on September 02, 2010, 09:13:40 pm
This is the only other Style pump listed for an AXX 2006 engine
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fww275%2FTaufe%2FScreenshot2010-09-02at211147.png&hash=b0fc956e30d1d6bff684f01710ed5d761d2cc8dd)
Post by: edd666999 on September 02, 2010, 09:17:32 pm
thats it! part 19 is the m8 thread, and 1b is the other bit.
Post by: bodger00 on September 02, 2010, 09:17:48 pm
Thats it Carl :happy2:
Good choice to not drive it.
Had another thought to undo the splined bolt you dont have to touch the nut above it. If you tried to undo this it would just bind against the bolt and cause a leak.
Post by: edd666999 on September 03, 2010, 03:32:56 pm
well i think its sorted....possibly.
no more leaks...from what i can see but does the fuel pump hiss? or is that some fuel escaping at very high pressure i can hear but cant see?
Post by: edd666999 on September 03, 2010, 07:03:19 pm
bollocks.
just cleaned the left nut, and VERY slowly fuel seaps down it, never turns into a drip.....
vrs carl whats the part number for part 19?
cheers
Post by: vRS Carl on September 03, 2010, 07:34:46 pm
2 Minutes turkish………
EDIT: Part no. is WHT 000 285 C listed as an M10X1 Banto Bolt - Will be about £4 :happy2:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fww275%2FTaufe%2FScreenshot2010-09-03at193815.png&hash=1c126e7cbd71109960b3a4e09a03694e36269987)
Post by: edd666999 on September 03, 2010, 07:40:22 pm
Many thanks!
Post by: edd666999 on September 03, 2010, 08:43:03 pm
Should there be any washers on those bolts?
Post by: vRS Carl on September 03, 2010, 08:45:49 pm
Not sure mate,
Not according to the Pic. I wouldn't think so but it would be best to check with a Stealer when you order a new one :happy2:
Post by: bodger00 on September 03, 2010, 09:23:26 pm
There were no washers on mine......... :popcornsoda: :popcornsoda:
Post by: edd666999 on September 07, 2010, 02:15:53 pm
Many thanks to all that replied, ended up with a new fuel pump and bolts. I couldn't fit the HPFP internals because I didn't have the correct tools, so just running standard fuel pump at mo, but to be honest I could take that pump off n back on in no time after doing it 10times already. Thanks to s2 ant for the pump and carl for part numbers!
Post by: vRS Carl on September 07, 2010, 03:38:39 pm
Your welcome.
What tools are you missing as the only thing i didn't have was the deep socket. Soon got one though from local tool shop :happy2:
Post by: cuprak1 on September 07, 2010, 05:18:55 pm
when we done ours with vrSY from here we lost the washer inside the pump which caused a leak, what a ballache but we found it and all went back together fine in the end. its a tiny ting brass washer which makes all the difference
Post by: edd666999 on September 07, 2010, 08:31:59 pm
Its the same tool you were missing!
Post by: Simon_2.0t on March 31, 2013, 11:14:21 pm
Balls, just done this to mine!  :sad1:
Off to VW on Tuesday for the two parts needed
Post by: MFGTI on December 30, 2022, 01:18:46 pm
Hi all, I have cross threaded the union bolt and my pump is leaking fuel everywhere - can someone let me know the part number to get a new bolt?
Post by: LC5F on December 31, 2022, 12:03:05 am
old thread to bump!
is this what you need? - https://www.akstuning.co.uk/shop/home/1289-tfsi-ea113-hpfp-banjo-bolt-wht000285c.html (https://www.akstuning.co.uk/shop/home/1289-tfsi-ea113-hpfp-banjo-bolt-wht000285c.html)
Post by: MFGTI on January 01, 2023, 06:31:55 pm
thanks for the reply, its actually the brass valve on the right side but I have found a new pump that I have bought and will take apart
