All Things Mk5 => Mk5 General Area => Topic started by: S2 Ant on September 09, 2010, 06:36:09 pm
Title: Valves on Monza 2's
Post by: S2 Ant on September 09, 2010, 06:36:09 pm
Quick question, i'm sure i've seen somewhere that the valves on the Monza 2's arent the typical item found on other wheels - is this the case? And if it is, i presume its a VW only item... Anyone know how much they are please?
Or any alternatives that fit?
Title: Re: Valves on Monza 2's
Post by: bacillus on September 09, 2010, 07:20:12 pm
If they are the metal ones then you are looking at around £12 each and that doesn't include the metal valve caps (you get a black plastic one).   :smiley:
Post by: kirkland on September 09, 2010, 07:27:23 pm
If you want the VW metal caps they are part No: 1KO907299 but there are other aftermarket metal ones about with 'GTI' marked on them if you like that kind of thing... :smiley:
Post by: S2 Ant on September 09, 2010, 11:23:19 pm
Mine look like the usual black ones on any other wheel to be honest but I have a wheel indoors waiting to go on and found a valve at work and it doesn't fittid hole in the wheel.
Post by: LouCyffer on September 10, 2010, 07:06:00 am
http://www.mk5golfgti.co.uk/forum/index.php/topic,18862.msg265950.html#msg265950
Post by: Ands GTi on September 10, 2010, 02:13:22 pm
I too need a metal valve for my spare Monza 2. The tyre garage had to put a rubber valve on as my metal one was missing.
Ant, if you find a place other than VW that does them let me know, ta.  :happy2:
