All Things Mk5 => How to Guides / Troubleshooting => Topic started by: cs01uk on September 09, 2010, 11:23:23 pm
Title: mk5 gti problems..
Post by: cs01uk on September 09, 2010, 11:23:23 pm
Bought an 07 mk 5 about 3 months ago since owning the vehicle i have had a remap. Just before havin this done it started to cut out at junctions whilst on tick over.. I had the re map done an everythin was fine but would still cut out once or twice whilst at a junction. Since then it has started to get worse! It cuts out more regulaly but only on tickover also seems a little under power and splutters when pulling away...
Had it plugged in to a diagnostics computer and no faults where shown!
Any help????
Also fitted a forge blow off valve which has started to hiss on low revs as if its losing pressure..
Title: Re: mk5 gti problems..
Post by: vRStu on September 09, 2010, 11:26:39 pm
Some things that affect idle are PCV and Oil Filler Cap.
Try removing the Forge valve and refitting the OEM one.
Post by: SeanyK on September 09, 2010, 11:50:24 pm
Absolutely as above - Take that DV off and put the OEM one back on, it's surprising how many problems can be caused by the DV itself.
Post by: gazbutS3 on September 10, 2010, 07:01:07 am
as VRStu said, alot of tickover issues are down to a leaky PCV
Post by: cs01uk on September 10, 2010, 12:58:32 pm
ok thanks for advice i'll giv that a go.. any idea what part number i need for replacement OEM one obviously i need to upgrade it becausde i hav had a remap..
Post by: cs01uk on September 10, 2010, 06:53:31 pm
Would it be the revision D that i need?
Post by: SeanyK on September 10, 2010, 06:59:09 pm
DV Part number is 06H 145 710 D
Thats the revision D :)
