All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Gti Jal on September 27, 2010, 11:54:19 pm
Title: Can Bus v dedicated wire to fuse board
Post by: Gti Jal on September 27, 2010, 11:54:19 pm
Hi guys I fitted an aftermarket Kenwood unit to my GTI and ran a wire to the fuse board for switched live. Its a PITA as because it kills the power to the head unit as soon as you turn the engine off. Its got a relatively long boot up time.
My sis in laws got and RNS510 in her MK6 and the unit does not turn off unless the key is fully removed.
What happens if I fit a canbus adapter, will I get sound until the key is removed in mine?
Title: Re: Can Bus v dedicated wire to fuse board
Post by: mortygttdi on September 28, 2010, 03:02:02 am
you need the wire to be in one of the top fuses to get ignition live this will give you power until the key is taken out...
Darren
Post by: Gti Jal on September 28, 2010, 06:59:28 pm
Thanks Darren!
Post by: GLIDN on September 30, 2010, 02:35:20 am
Darren
I'm assuming you mean the top fuses on fuse panel right hand side of dash?
or are you meaning main fuse panel behind the dash above the accelerator pedal?
Post by: mortygttdi on September 30, 2010, 05:43:00 am
Sorry yes the interior fuse panel to the side of the steering wheel :happy2:
Darren
Post by: Garth on September 30, 2010, 10:14:57 am
Another ignition switched live is the main power cable to the back of the climate controls... that feeds my phone charger  :happy2:
It's closer to the head unit thatn the fusebox
Post by: mortygttdi on October 01, 2010, 08:42:33 am
Funny you should say that Garth I just come across this on my photobucket :happy2:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fss4%2Fmortygttdi%2F24012009081.jpg&hash=e78ed23db9592e453b6261854338e9c365518376)
Big connector pin 20 black/blue wire
Darren
Post by: QD MBE on October 01, 2010, 09:01:45 am
halfway down the page....
http://www.my-gti.com/601/addition-of-extra-circuits-to-the-volkswagen-golf-jetta-passat-eos-scirocco-rabbit-fuse-box (http://www.my-gti.com/601/addition-of-extra-circuits-to-the-volkswagen-golf-jetta-passat-eos-scirocco-rabbit-fuse-box)
