All Things Mk5 => Mk5 General Area => Topic started by: Lyons on October 12, 2010, 10:32:59 pm
Title: Swapping cluster lights from blue to White
Post by: Lyons on October 12, 2010, 10:32:59 pm
Has anyone ever successfully swapped the blue of the instrument dials and the climate displays to white?
I imagine the latter shouldn't be too tricky, but what about the former?
Any info appreciated.
Title: Re: Swapping cluster lights from blue to White
Post by: monte on October 12, 2010, 10:40:51 pm
I think Darren will know (Mortygttdi) I think he once mentioned changing the white dot matrix display too (highline)
Post by: Lyons on October 12, 2010, 10:43:03 pm
Aye, I can recall something about swapping the highline.
Sadly I just have a midline, but I'd settle for swapping the blue to white.
Post by: stealthwolf on October 12, 2010, 11:52:04 pm
The blue light can be changed but it's a bit of a pig. There are these tiny mounted devices that are smaller than LEDS. You need to replace something like 20 of them.
Post by: mortygttdi on October 12, 2010, 11:54:45 pm
Speak to Garth I know he did his so could give you some advice.
Darren
Post by: Lyons on October 13, 2010, 06:22:00 am
Is that for the cluster?
I'll send him a pm, cheers Darren.
I've a mate that does vauxhall SMD conversions and has said if I can remove both parts he'll give it a go. From memory the cluster removal is quite easy, and I'm assuming the climate control is just the next thing to be removed after taking out the trim for a HU swap.
If I remove the cluster will it need recoding when i put it back, or is that only if you put a new one in?
Post by: Garth on October 13, 2010, 06:44:21 am
I've done this on mine. Take a look in my build thread (link in my signature) for details. Not massively difficult but then it is easy to mess up if you aren't careful!
Post by: Lyons on October 13, 2010, 07:23:20 am
Found your thread this morning Garth, PM sent with a couple of questions!
