All Things Mk5 => Mk5 General Area => Topic started by: SeanyK on October 26, 2010, 07:13:49 pm
Title: Temperature gauge taking a while to get to the middle?
Post by: SeanyK on October 26, 2010, 07:13:49 pm
Hey folks, I know it's cold weather outside and all that, so it's going to take longer for the car coolant to warm up, however, i've noticed the last few days (it may have been happening longer but only just noticed).
When driving in the morning, from cold, gently driving the car temp gauge makes its way up slowly... When it gets to about 1/4 or just past it, it basically stays there for ages, im convinced i've seen it go past it, then back down again a few moments later? And it will eventually get to the middle and stay there (perhaps 15 minutes or more after?) This is driving at a constant speed, and also stop/start heavy traffic driving.
The only thing I can think of are;
1) Coolant temp sensor (but VCDS scan does not show faults)
2) Sticking thermostat
3) I had my Cambelt & Water pump changed @ VW in August... So I can't see it being the water pump... But you never know?
Any ideas?
Title: Re: Temperature gauge taking a while to get to the middle?
Post by: RENNTAG on October 26, 2010, 07:18:12 pm
my mk4 golf had a similar issue to this,
would gain som temperatue then drop back down a bit.
trned out it was the coolant temperature sensor.
did not show a ault code for it though, just replaced the sensor.
Post by: ub7rm on October 26, 2010, 07:50:06 pm
Mine does exactly this in cold weather, nothing to worry about if its a fairly short journey.
1st ten minutes for me is through town at 30 mph / traffic etc and it will warm up to about 45 deg on the gauge.  Then when I hit the dual carriage way it drops a little from this but has risen a bit by the time I get to work (another 10 mins ish on the dual carriage way).
Last winter I travelled about 50 miles through temperatures ranging from -5 to -15 and even over that distance it didn't warm up properly ...
Post by: SeanyK on October 26, 2010, 10:18:07 pm
That sounds exactly like my drive to work... Around 40mph for about 5 minutes, then stop start through a village at about 20mpg, then onto a dual carriageway for 5-10 mins, by the time I get to end of the journey (approx 20 mins) the temp gauge is firmly in the middle.
Post by: Teutonic_Tamer on October 27, 2010, 04:02:13 pm
Engine coolant temperature sensor.  Common-ish problem.  £20ish for the part - plus labour to fix.
All you sufferers really need to get it changed - because the 'apparent' low temp reading from the ECT will cause the ECU to constantly over-fuel - and possibly damage your cat.
Post by: Kalpsn2000 on October 27, 2010, 04:10:26 pm
So out of interest, should the temp needle be in the middle pretty quickly? Approx time?
Post by: Teutonic_Tamer on October 27, 2010, 04:14:03 pm
How long is a piece of string?  There are way too many variables to give a definative answer - but basically, the needle should rise in a linear, constant progressive manner.
Post by: SeanyK on October 27, 2010, 05:02:05 pm
I've changed a few of these on Golf MK4 1.8T's and previous Ibiza Cupra 1.8T's also, quite an easy job, so hopefully the MK5 GTI is similar!
I will find out the part number and post it on here for anyone interested,
Sean :)
Post by: ub7rm on October 27, 2010, 07:15:19 pm
Hmm interesting.  Is there one ECT or two?  In my case I'm not all that convinced its a problem.  In the summer the engine is up to temp quite quickly but in the winter it does take longer.  Which is what I would expect?
Post by: Teutonic_Tamer on October 27, 2010, 09:22:48 pm
There should be two.  One on the engine (usually on the cylinder head or near the thermostat), and one on the radiator.  The one on the engine has more effect on the engine ECU (for fueling, cat warm up, etc), and the one on the rad controls the coolant control module - basically provides info for the rad cooling fans.
It is perfectly normal for the engine to warm up quicker in the summer compared to the winter.
But how are you gauging how the engine warms up - from the actual coolant gauge?  Another reliable way, if a little 'seat of the pants' method is how quickly the heater warms up.  This is most accurate if the climate control temp is set to 'HI'.
Post by: SeanyK on October 27, 2010, 10:06:07 pm
Looks like the part number needed is 06A 919 501 A
Post by: SeanyK on November 15, 2010, 08:03:30 pm
I changed this today folks, will see if it makes a difference, but the job itself is very easy! Easier than on the MK4 (& Ibiza Cupra's etc)!
It is located to the right of the engine block when looking down at the engine bay, facing the side of the battery.
Pop retaining clip off with flathead screwdriver, pull sensor out, take old O-Ring out, replace O-Ring & Sensor, put back retaining clip.
...And put some coolant back in to cover what just flew out!  :grin:
Do not do this job when the engine is warm!!!
Post by: ub7rm on November 26, 2010, 04:39:34 pm
Any feedback on this?  Starting to wonder now if its not so 'normal' for me.  I'm finding the car a bit sluggish to start from cold these days and it doesn't hold the revs up for a couple of minutes like it used to either.  Wondering if this is all temp sensor related...
Post by: Richn83 on November 26, 2010, 07:14:38 pm
Interested in the quicker drop in engine revs at cold start, ive noticed mine do the same since the temp dropped.  Would be interested to know if anyone else has had this sympton, havent scanned the car yet maybe I will do a quick one tonight.
Post by: SeanyK on November 26, 2010, 07:19:52 pm
Hey folks, well it doesn't go to the middle and back down again etc anymore!
It's a very easy job to do so i'd change it if I were you just to rule it out :)
Post by: ub7rm on November 27, 2010, 05:14:34 pm
To rule this out as whats causing some dicky starting from cold and in case its not just the weather causing the car to take ages to warm up I replaced this today.  I'd like to add a bit of advice to Seanyk's instructions:
Do NOT do this when its -2 and dark outside.
In your excitement after pulling the old sender out and coolant is pi$$ing out; don't assume the old O ring came out with the sensor.  Check that it did come out.  This will save you a lot of swearing and wishing you hadn't started this job when you cant get the new sensor in and coolant continues to leak out.
Otherwise very easy.  Still to see if this has helped but the engine did start no probs after fitting.
Paid about £35 for sensor and new O ring.
Post by: SeanyK on November 27, 2010, 05:44:39 pm
http://www.vwspares.co.uk/product_info.php?products_id=678
Sensor for £5.91 you'll need to add an o-ring to that too.
Post by: ub7rm on November 27, 2010, 05:58:56 pm
 :surprised:
Post by: gigolo456 on March 06, 2013, 10:42:25 am
Hi Folks, sorry to resurrect what is a very old thread but is quite pertinent to my query i think! This morning, different and longer route to work, it took a full 27 minutes of steady 60mph driving for the thermostat to rest at 90, although it didn't/doesn't budge one iota once it reaches 90! Now, granted, the temperature outside was showing as 2 degrees, and it was foggy, but should it really take this long to get to 90?? I had my radiator, small(er) fan, thermostat, and engine coolant sensor gauge all replaced last September, as well as engine coolant top-up, so all very new! My car is a 2005 GTi, all else seems fine, the heaters were working fine inside the car, average mpg was a nice 35, and performance seemed totally fine! Could it merely be that all my new cooling systems/parts are working more efficiently than before perhaps!!??  :confused:
Post by: homesqueeze on March 06, 2013, 06:31:34 pm
Sounds pretty much like what my 05 is doing at the moment. It can take nearly half an hour for it to get to 90, but stays there once up to temp. Was just hoping it was down to winter temperatures slowing it down, but I don't remember noticing this in previous years.
Post by: gigolo456 on March 06, 2013, 07:19:40 pm
Getting a LOAD of work done in 2 wks time, at the place where all the cooling items were replaced, will ask bout this! At least its not budging once it does hit 90, as before items were replaced, the thermostat was up and down like a yo yo!!
