All Things Mk5 => How to Guides / Troubleshooting => Topic started by: GeeTeeI on November 06, 2010, 05:52:54 pm
Title: How to dismantle key?
Post by: GeeTeeI on November 06, 2010, 05:52:54 pm
I've seen blank key covers for sale and mine looks a bit tired - how do you get the thing open to get the gubbins out for a switch over to a new one?
Is it as simple as they say on the ebay listings (just change the keyblade and transponder into the new one)?
Thank you
Title: Re: How to dismantle key?
Post by: Eddy30 on November 06, 2010, 06:03:55 pm
Not sure exactly mate but if you flick the key out and get your thumb on the silver bit and push away from you it splits in half leaving you the key in one part and the buttons in another,think from there you can then split the lower part by pushing in the plastic tabs,there is also a small pozi screw under the Vw badge which should split the key part, hth
Post by: bacillus on November 07, 2010, 11:35:53 am
http://www.riskin.org/vwkey/
Post by: GeeTeeI on November 11, 2010, 09:39:38 am
Hmmmm
I've hit a problem. Ive changed over all the innards and the blade. Put it all back together, and while it opens and claws the car and boot, when I come to start the car it says "immobiliser active".
Can anybody advise what I need to do? Is there something in the old key that talks to the car?
Mark
Post by: Richn83 on November 11, 2010, 10:11:24 am
Well by the sounds of it you have replaced the front part of your key too, this part holds the immobiliser transponder.  so go and get the old front part of your key where the blade secures and re-use this part unless you are going to get the new immobiliser transponder re-synced to your car immobiliser.
Post by: TonyZed on November 23, 2010, 08:20:19 pm
Just take the transponder out of your old key. The new key won't have one if it is from ebay. Anyway, VW will charge  to recode all your keys to match a new transponder, (and you do have to do them all at the same time,) you can't do it yourself without the right equipment.
TonyZ
