All Things Mk5 => Mk5 General Area => Topic started by: Hendo on November 09, 2010, 06:31:33 pm
Does anyone know the correct pressure's on the standard ED30 wheels?
It tells me in Bar on the filler cap but i'd like to know the figures? I had a look at a converter and seems to come out about 37 to 4p psi? Would that be right?
Rich
36 PSI :happy2:
Ok cool 36psi just seemed a bit high to me.
I use 37psi - I set the machine to read in bars TBH but if you change the units to PSI, it comes up with 37psi. Anyway, these are recommendations. Depending on usage and/or load, you need to change these.
Interesting - when I worked it out it came to 36, hence my settings! I set mine on having no load in the back, because I rarely have rear passengers or an overloaded boot.
1 bar = 14.5 PSI :happy2:
http://en.wikipedia.org/wiki/Bar_%28unit%29
Or go to Google and type in
convert 2.6 bar to psi. Comes out as 37.7 psi.
37.7 is what I got. Most of the other car I have had the tyre pressure has been about 33-35
