All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: damoegan on November 18, 2010, 09:40:40 pm
Title: RCD300 + Parrot hands free
Post by: damoegan on November 18, 2010, 09:40:40 pm
How easy are they to fit to a RCD300? Plug and play?
The Mrs wants one for chrimbo for her GT Sport  :smiley:
Title: Re: RCD300 + Parrot hands free
Post by: damoegan on November 19, 2010, 10:21:40 pm
 :sad1:
Post by: GLIDN on November 20, 2010, 04:20:25 am
RCD300 simple plug and play.
As for the Parrot kit depending on unit you have and wiring loom with multifunction steering wheel
If you are using the button module from parrot, The hardest part will be to get a ACC power otherwise it will always be on.
If you want to use the MFSW, Then get the wiring loom with Can adaptor. then you it's all plug and play.
hope this helps.
Post by: damoegan on November 20, 2010, 03:04:57 pm
No MFSW on the Mrs' GT, so it should be just olug and play then  :drinking:
Post by: GLIDN on November 21, 2010, 05:06:54 am
Yes but your Bluetooth will stay on, so you require acc feed.
But super easy to install.
