All Things Mk5 => Mk5 General Area => Topic started by: Lyons on December 31, 2010, 12:22:49 pm
Any good detailed guides on removing the steering wheel in a Mk5 online?
A mate removed mine in a Bora I once had and it appeared easy, but the airbag bit put the fear in me.
I did a brief one in my DSG fix HOW TO
http://www.mk5golfgti.co.uk/forum/index.php/topic,22794.0.html
Onve youve got the airbag off if just a case off undoing the triple square bit in the middle of the wheel!
Cheers for that.
Any idea what size the spline bit is to remove the wheel?
M12 i think! :happy2:
M12 indeed! Steering wheels has been of and back on, with new wiper stalk fitted.
Sadly I connected the battery again with the wheel off to check that the wipers were working, and now the airbag light is on.
Will a 15minute battery pull fix it, or is it a job for vagcom?
No... ive tried that before! Youll need VCDS to clear it! :happy2:
About time I did mine I will do it Monday.
Remember to mark the position of the steering wheel relative to the steering column shaft before removing the wheel.
Please also note that you should only thighten the bolt that holds the wheel in place up to 5 times. Replace it the sixth time.
