All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: SteveS on January 16, 2011, 05:55:27 pm
Ok, so i just fitted a Forge vacumm tap (the one on top of he engine) and there was oil inside. normal? :confused:
^^ Whats that do?? :confused: not a chav sounding Corsa dump valve Steve?? :scared:
its so you can connect the Forge DV and/or gauge...
oh i see.. oks :happy2:
Off topic Steve, but are you fitting a boost gauge?
fitted, yes
anyone?
Its normal to have some oil residue as the pipe that fits onto the inlet manifold where the tap is fitted is a breather that recircs wasted oil vapour from the engine.
hum, fair enough, but then surely thats a bad place to connect a DV solenoid and a boost gauge! its going to bet all bunged up and cause damage
