All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: garrardrj on January 24, 2011, 07:53:27 pm
Can the speedo be altered to read accurately? Mine reads ok up to 30mph then at 100 it is really only doing 85...yes looks flash as 0-100 comes up quicker but i want it accurate.
In a word no. But you can get the correct reading up on the climate control panel. :happy2:
Wot ? :confused:
You can get a few settings up on the panel were your air-con temp is, cant remember how to do it, it was in a thread of tips and tricks, i think you can get it there using VCDS, but you cant calibrate your actual speedo. :happy2:
You can adjust speedo Calibration see herehttp://www.ilexa.co.uk/forum/index.php?topic=27072.0 (http://www.ilexa.co.uk/forum/index.php?topic=27072.0) note Uwe from Ross-techs comments :happy2:
