All Things Mk5 => Mk5 General Area => Topic started by: SeanyK on January 26, 2011, 01:59:44 pm
Hey folks,
Just a quick question to rule something out... I had a MFSW fitted and coded last year at VW all worked fine...
But I have recently fitted a Dension Gateway5 to my car, along with RCD510 & a AF Can-gateway.
When I did the swap im pretty sure I matched the CAN installation list to the old one, but I can't get the up/down buttons to work (track skip or REW/FF) on the MFSW even in the audio menu...
They do work to scroll through menus such as MPG etc etc but not in the radio menu.
I know I had this issue with the REW/FF before I had the highline dash, but obviously that was fixed ages ago when I put the highline dash in.
I just wondered if the MFSW is something that needs re-coding since swapping CAN-Gateways?
Sounds like its a problem between the Denison and the wheel mate not a coding issue.
Was this not one of the known problems with the Denison 5 gateway??
I thought it might be, to be fair they've been quick to help so far but I had a sudden thought that it might have been since swapping the Can-gateway.
I've not seen it mentioned, the main problem seems to be when trying to use it with a mid-line dash.
The bluetooth phone functionality is superb! And it streams audio from the phone too, has phonebook, in dash & on rcd dialling etc Just the pesky back and forward buttons!
If they fix it / let me know what to change, and the Rew/FF & Track skip buttons work, then I would give it 10/10 but until then... 6/10 :grin:
- Update -
Dension support just said they've not had any problems using these steering buttons! Grrr lol
OK, I did find one section, in the RCD510 long coding area, one of the options was 'short press' button or something like that.
When I ticked it, voila, I can now change tracks using the up/down buttons, although they still don't FF/REW when holding them down!
...Halfway there! :laugh:
Do you have the early Mk5 MFSW or the late one with the star? Mine's an early one and the same buttons (next/previous) don't work with the RNS-510.
