All Things Mk5 => Mk5 General Area => Topic started by: johnhol78 on January 29, 2011, 09:34:41 pm
Is there anyone who has experience with the GTi in the Uxbridge?
I ask because I bought mine a week ago and while I love the car I'm not sure if the turbo is working. I hear people talk about the turbo kicking in though mine seems to pull all the way through the rev range. Think it might be the DV as I haven't changed this.
I hear a whistle/hiss almost immediately and searching the forum I've found it shouldn't do this.....
Just wanted someone to come or I'll go to them and see what they think.
Will probably chnage the DV anyway....
Also a DSG version I drove felt alot faster though I maybe just imagining it :(
J
of course it was :happy2:
I mean I felt the kick of the turbo more.....i think.
Might just order a DV and be done with it.
I'm in Hemel Hempstead so could have a nosey if you like and wanted to head over this way?
I live in Uxbridge...
Cheers mate.
Will order a DV this week and hopefully fit it Saturday....if that doesn't help then I'll give you a shout.
Will also have a drive tomorrow and really listen to the engine and see if I can feel any kick...as I said it seems to be just a gradual acceleration.
Thanks again....if you can email me you contact (msn or something) then I can get hold of you :happy2:
Would you here the turbo when just revving the car...what revs should the hiss start??
Whereabouts mate?
Do you know about the turbo etc? I live opposite the drive through McDs....Oakside :happy2:
I know where McDonalds is, I'm off Cowley High Road.
I know very little, & I mean little, about the engine/turbo. Mine is a standard DSG but if you want to look or listen to anything I'm sure we can sort something out.
that would be great....see if yours sounds the same as mine... :confused:
what about tomorrow....can do upto 10am or after 5pm..
could meet at currys car park...not sure my neighbours would be happy with me revving my car :evilgrin:
I can't do before 10am tomorrow & am out & about the rest of the day & evening. I'll PM you tomorrow.
Right been a for a learning drive and almost certain it's not boosting properly.
No real kick from the turbo just a gradual acceleration..
Would a diagnostic check show what was wrog, even if it's the DV?
Anyone with a diagnostic reader (or whatever they are) in the area?
As above, can take a look if you like.
Will be able to see what levels of boost you're getting and check for fault codes etc.
The Golf doesnt really have a kick tho and is a smooth in power delivery, esp if standard
Think I maybe expecting more kick than normal....Never had a turbo so no idea what to look for.
Ordering a DV from awesome-gti.......are these ok? It's the piston type which I believe is the D version.
Says OEM so should be fine.
Personally, i'd check a dealer price first and if poss a TPS at a dealer as its going to be possibly cheaper for the same item.
But if you think something is up i'd check that first, as if there is nothing wrong then its money being spent for nothing
there is a kick... but dont be expecting a full on kick...
mine was the same not too long ago and though there was little reduction in power wasnt feeling any kick when I floored it. Took it in to the dealers ran a adiagnostic (20 odd quid) and it turned out to be a loose air hose and was fixed free of charge...
drove it home and felt a lot better...
What do you mean my a TPS at a dealer?
Would be able to pop up one night this week if possible.......off today but let me know when would be best.
TPS = Trade Parts Specialists
http://www.thetradepartsspecialists.co.uk/ (http://www.thetradepartsspecialists.co.uk/)
Matt
Matt
Worked it out and went tonight....bought and ready to fit.
my gti wasnt boosting properly and hissing alot. turned out to be the dv.. i changed it for the revised vw part. boosts lovely now. i am in aylesbury by the way.
when u take dv off the car its only 3 screws and a plug if i remember correctly. once off have a look inside the black plastic casing and you will see a rubber stretchy type material, lol... that tends too perish over years and develops holes in it where the boost escapes. got my old dv here to prove it.. :jumpmove:
im in twickenham area mate with vagcom , i have my daughters this weekend but you are more than wellcome to drive over and i will scan your car for you and if time might log your boost as well.
Rob.
Rob.
That would be ideal.....especially the boost logging....
Hopeing to fit the DV tomorrow night or Saturday morning so if things don't imporve I'll give you shout if that's ok..
yep thats fine mate.
Started the job of changing my DV.
Loosened the wheel nuts, jacked it up and had the axle stand ready........flaming jack wouldn't lift the car high enough to get the axle stand under the rear wishbone joint....AAARRRGGHHHHHHHH
So wheel back on, lowered the car and packed it all away, will have to rethink the strategy a bit more and start again in the morning...
:sad1: :sad1: :sad1: :sad1: :sad1: :sad1:
