All Things Mk5 => How to Guides / Troubleshooting => Topic started by: wallybanger on February 06, 2011, 11:03:39 am
Title: Abs/ESP problem
Post by: wallybanger on February 06, 2011, 11:03:39 am
Had no problems at all with the car untill last week when i put a set of BBS ch 9x18s on last week all running the same tyres and same pressures now once you start driving no problem untill 40 mph + then the lights for the ABS,ESP and flat tyre lights a come on and wont go off untiil car is turned off and on again . i have checked tyre pressures and all are fine . really annoying warning lights but abs still seems to work esp def isnt but lol :confused:
Title: Re: Abs/ESP problem
Post by: edd666999 on February 06, 2011, 12:02:22 pm
have you pressed and held down the tyre pressure warning button till it pings at you
Post by: stealthwolf on February 06, 2011, 12:08:03 pm
I posted up about a similar problem. On mine, one of the ABS sensors broke and since the entire system is linked, you get errors in abs/tcs/tp lights - all were yellow. Tyre pressures, brake fluid etc were all ok.
Replaced under warranty.
