All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: rdfcpete on February 09, 2011, 07:16:58 pm
Title: Replacing RNS510 DVD Drive
Post by: rdfcpete on February 09, 2011, 07:16:58 pm
Is there a 'How to' or step by step guide on how to replace the RNS510 DVD Drive please?
As part of http://www.mk5golfgti.co.uk/forum/index.php/topic,21119.0.html - I need to know how to do it as I've acquired a spare (and in theory working) drive  :happy2:
I've just got round to establishing the screws on the top of the unit are Torx T7? If they're not, then I'm stunned as a T-8 was too large and  T-6 didn't grip!  :scared:
Thanks.
Title: Re: Replacing RNS510 DVD Drive
Post by: mortygttdi on February 09, 2011, 07:27:15 pm
Hi Pete
There is 2 screws at the front of the drive but these are the same screws that hold the top on so you'll have already taken them out.
Then there is 2 screws at the back of the drive once you have taken the top off the RNS510, once you have got this far its a simple lift the drive up unplug the ribbon cable and swap over. Then put it all back together? Watch the front of the drive has it is fiddly to get back in place, if you do it wrong then is will not line up with the cd slot on the front.
Darren
