All Things Mk5 => Mk5 General Area => Topic started by: vRS_Pagey on February 20, 2011, 05:20:49 pm
Just after the definative answer here, will a MK6 wheel fit a MK5 and thus by default a MK2 Octavia?
I only ask because I have the opportunity to buy a set of 16" MK6 steelies to use with winter tyres on the vRS. :happy2:
Yes they are the same PCD (5 x 112)
I guessed the PCD would be the same and as long as the offset isn't much lower than ET 45 they should be ok, but I have found conflicting information regarding the centre bore, the 2 main sizes are quoted 57.1 or 66.1, I'm sure the MK2 Octavia and MK5 Golf are the former?!?
Just get a Spigot if thats the case.
Just looked on ETKA but it doesn't say what the Centre Bore is.
:confused:
Yes they are the same. I just put the part no. in to see what cars they fit
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fww275%2FTaufe%2FScreenshot2011-02-20at174443.png&hash=9c35b867aa87415c14655c9364c984fec4dcd840)
:confused:
It's an insert for the bore so if you had a 66.1 wheel you could get a spigot to reduce it to 57.1 and therefore fit the hub :happy2:
Cheers Carl, I take back all the offensive comments I have made. :notworthy:
:grin: :grin:
Trust me you'd do well to offend me :happy2:
Mmmmm! I love a challenge......................
...........unless it involves getting under the car! :laugh:
This is the wheel part number: 5KO 601 027. Carl can you or anyone else with ETKA confirm the spec is correct to fit MK5?
Is there no letters at the end?
You mong. :P
The correct part no. is 5K0 601 027 not 5KO :booty:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fww275%2FTaufe%2FScreenshot2011-02-21at112410.png&hash=8958488eb9220ce397d38255bfce327181ad52c7)
It fits the following. (But it doesn't mean they won't fit a MK5 or an Octy)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fww275%2FTaufe%2FScreenshot2011-02-21at112126.png&hash=d948800dae12b68524073af15c675795b4a99174)
I copy and pasted from the advert so blame them for grammatic errors!! :booty:
What I really need is the specifications.....offset etc!
They are:
6.5J x 16" H2 ET50
ET50 :surprised: that could possibly rule them out then! Iirc the 18" Zenith is 7.5J ET51, if thats correct they will sit inboard a further 12mm..................unless I fit spacers they will look uber carp!! :sad1:
They are Steel Wheels and 16"
Are you after them for winter wheels?
Bingo! :happy2:
So what you worried what they look like for??? If they do the job and stop you pirouetting into a ditch who cares :confused:
Coming from a man who fits DRL's in his boot, thats rich! :laugh:
I get your point though........ :drinking:
The DRL's have 2 purposes.
1. They illuminate the boot and 2. If i do pirouette into a ditch i can open the boot to signal the rescue planes :laugh:.
You should know by now i don't care what others think. As long as i amuse myself then it's water off a ducks back to me :booty: :P
Having gazed upon your face, I can see why you would have to think that way! :laugh:
:grin:
