All Things Mk5 => How to Guides / Troubleshooting => Topic started by: DamoP on February 26, 2011, 12:06:14 pm
Title: retro fit tyre pressure kit
Post by: DamoP on February 26, 2011, 12:06:14 pm
i have just brought the tyre pressure kit off another member (switch + loom) has/does anyone know how easy if is to fit?? would it need coding to my car??
Title: Re: retro fit tyre pressure kit
Post by: Eddie-NL on February 26, 2011, 02:23:33 pm
easy to fit
Post by: DamoP on February 26, 2011, 04:33:41 pm
Is there a fitting thread that you know of?? and will it need coding??
Post by: Snoopy on February 26, 2011, 06:04:55 pm
If we are talking VWs TPMS
This Maybe of some help
http://www.mk5golfgti.co.uk/forum/index.php?topic=7677.0
and
Here's a bit more detail.
Basically it can be installed without cutting any wires you only need to run one wire from the swtich up to the ABS controller behind the battery.
The other connections can all be taken from the ESP swtich and using a combo of pre-made wires and a couple of connector housing it will look something like this: -
Wires taken out of the ESP switch into another connector housing
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fkk207%2FStevep_010%2FDSCF3383.jpg&hash=61c893da63205be4d72a3165a19b11c58ba1b1f5)
New loom reconnected to ESP swtich to "pick-up" the required power/signal's
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fkk207%2FStevep_010%2FDSCF3384.jpg&hash=81cc251bc22e32660b2d741c5721a09ebc764021)
All complete and looking OEM (other than I only had black cable ties and OEM fit is clear)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fkk207%2FStevep_010%2FDSCF3395.jpg&hash=81809c396eee30b7f879b5f4646b12e29d9feb8b)
  :smiley:
Post by: DamoP on February 26, 2011, 06:19:20 pm
Thanks mate ,  ill tackle that next week. where did you go through the bulk head?? is it obvious where the connection goes on the abs controller??
i see you have 4 switches on yours , what are the other 2??
Post by: Snoopy on February 26, 2011, 09:04:53 pm
Not my photos there SteveP's of his mk6 but its more or less the same.
His has lots of options.
It had the adjustable suspension, Parking sensors, ESP switch.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fkk207%2FStevep_010%2FDSCF3398.jpg&hash=13edb2ff2b151d8cefd0614d61dab9dcca56fea5)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fkk207%2FStevep_010%2FDSCF3440.jpg&hash=155244cdea0d35bc7b623e146e6fc9c0aeb0596a)
The coding via VCDS is very simple and just tick boxes.
Post by: parks on February 26, 2011, 10:20:26 pm
Slightly off topic, but what could you use the other blanks for? On a mk5 without the fancy suspension.
Post by: StephenED30 on February 27, 2011, 01:57:23 pm
List of switches here.
http://carstyle4you.com/index.php?cPath=16_22_33_47
Post by: DamoP on March 02, 2011, 04:45:14 pm
cheers for all your help guys , was easy enough to do.... apart from getting the wiring through the bulk head
Post by: whiteatom on March 10, 2011, 10:33:36 pm
Hi
Can anyone point me in the right direction for some instructions to fit this kit ? I have the loom + switch but no english instructions.
Many thanks in advance
Post by: DamoP on March 10, 2011, 10:40:09 pm
Hi
What do you need to know?? all the info i used if off this thread
Post by: whiteatom on March 10, 2011, 10:47:17 pm
The kit I got has a black plastic plug connector and then 3 grey wires (not connected in ) with no instructions on what order they go in ! I was expecting a plug and play loom for the switches then connect the 1 wire to ABS unit + re - code.
Any info ?
Post by: Eddie-NL on March 11, 2011, 06:33:18 am
You need to remove 3 wires from the ESP plug, then you insert them into the plug supplied. The 3 wires on the loom go to the ESP plug
ESP Plug
GREY Wire (pin 3) - Remove and fit to pin 1
BROWN Wire (pin 6) - Remove and fit to Pin 3
BLACK AND BLUE or BLACK AND GREEN (pin 4) - Remove and fit to pin 2
Post by: whiteatom on April 25, 2011, 01:23:27 pm
Just in process of fitting , can anyone confirm which pin the wire to ABS controller needs to be in ? On the loom wire it says pin 07 , but in Germany instructions says Pin 27 / Pin 41 ?
Many thanks
I have a mk5 Gt tdi 4 motion on 05 plate if this makes any difference ?
Post by: Eddie-NL on April 25, 2011, 01:56:03 pm
PIN 27
unless you have DSG
Post by: whiteatom on April 25, 2011, 07:10:15 pm
Excellent thanks, all working + coded now.
