All Things Mk5 => How to Guides / Troubleshooting => Topic started by: v2brett on February 28, 2011, 08:21:00 pm
hi guys i seem to have a small vac/ air leak coming from the pipe circled in the pic below, i take it this is not normal?
What is this pipes function and how do i remove it as it has no visable clips or clamps holding it on
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fw199%2Fv2brett%2FSDC10647-1.jpg&hash=a4e15673c3ef23f6ec6ef0d63569ca65462683fe)
thanks
Brett
if it helps anyone in the future, ive just had a good hour googling and its a pipe connected to the vac pump and just pulls off, :happy2:
Was there any noticeable symptoms of the vac leak? Did you notice any difference in your brakes after fixing it?
it was only a very slight vac leak which could only just be heard (i have no engine cover fitted), and ive not driven the car much since but will report back when i do over the weekend :happy2:
I had to replace this pipe on my car a few weeks back. It had started to perish and split in quite a few places. Its only around £25 ish.
have you got a part number please Alex? the pipe seems ok on mine its just the rubber was a bit squashed where it joins to the vac pump, so ive turned it and it seems to have stopped for now.
but for the sake of £25 ill put a new 1 on :happy2:
That pipe is the vacuum supply fitted to the servo from the cylinder head, they have a bad tendancy to crack due to the temperatures of some of the components round it!!
