		General => Detailing => Topic started by: critter on March 07, 2011, 08:41:36 pm
 Hi clayed the car for the first time at the weekend,cant believe the differance,such a great product.
 Is it safe to do regular,because i think im hooked.
				It does do a great job of removing bonded contamination.
 As long as you have protected the paint with wax or a sealant you probably don't need to clay it for another 6 months.
 Even careful claying with plenty of lube and a mild clay can leave some marring so best no to over do it.
				As above. Claying doesn't need to be done more than twice a year. You would gain no benefit but risk likelihood of marring. I'd follow any claying session with a polish. Use adequate lubrication - bilt hamber clays use water as lube. Personally prefer the dodo juice stuff.
 And finally, protect your finish with a wax or sealant.
				My current fave clay is dodo juice gentle grey with meguiars last touch diluted 1-1 with water as lube.
 Meguiars own mild clay is not bad at all, same goes for autoglym clay.
 Dont like the poly clay much personally though.
				This ones for VC.
				 :chicken: :chicken:
 Ian. I worry about you sometimes  :laugh:
				 :scared: :signLOL:
 Only sometimes  :grin:
				beat me to it hedge  :signLOL:
				Thanks for letting us know, il leave it till the summer,just for the record it was a megs bar and used the autoglym lube.
				autoglym lube is their quick detial IIRC, if you've finished that get some meguiars last touch as I said pal, works out much cheaper and can use it for other stuff!
