All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: jonnyc on February 27, 2009, 11:50:42 pm
Title: Boring question..
Post by: jonnyc on February 27, 2009, 11:50:42 pm
Hey all..
Would anyone be able to make an educated guess on the following question..
What would be the weight of a 1 meter long piece of 76mm diameter 3mm think stainless steel??
I told you it was boring..
Reason is that im looking at having a titanium centre pipe made for my car, just trying to figure out if its going to be worth it!?
Jonny
Title: Re: Boring question..
Post by: gazbutS3 on February 27, 2009, 11:53:05 pm
it depends what type/grade of stainless Jonny, there are various grades and they will all have diferent weights
Post by: jonnyc on February 27, 2009, 11:57:13 pm
T304, sorry, should have mentioned that..
I have found out the following..
Steel 8.0 grms / ccm
Ti 4.95
Kind of helps, as the Ti exhaust would be only 1mm thick it should be a lot lighter! Take in to account the relative weight difference and that should make a hell of a difference % wise.. Just need to find out how much the centre section of the current exhaust I have weights up at..
Post by: QD MBE on February 28, 2009, 10:41:39 am
Hey all..
Jonny
3MM thick is a bit hefty for an exhaust.  I reckon the material thickness is about 20SWG which is 0.9mm thick.  The weight saving is likely to only be 1-2kg at the most.  However the sound properties of Ti are totally different to SS, due to the different stiffness properties.
Post by: jonnyc on February 28, 2009, 01:01:22 pm
Hey all..
Jonny
Ah ok, so the thickness would be similiar with the Ti pipe too possibly? Hmm.. I have heard that you get a much more metallic sound from the exhaust using Ti, much like inconel etc..
Post by: QD MBE on February 28, 2009, 02:47:02 pm
We use Iconel blocks as reaction bars, when riveting aircraft structure.  Now that is hard stuff!
Post by: gazbutS3 on February 28, 2009, 04:34:31 pm
we use tungsten 1's as well for riveting :happy2:
Post by: JPC on March 02, 2009, 10:52:20 am
ah...i use this
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fwww.anticsonline.co.uk%2Fl.aspx%3Fk%3D13754&hash=b4305987533ed2af15c7477b9c0b6970dd5b0144)
miles better!
