All Things Mk5 => How to Guides / Troubleshooting => Topic started by: harryralston on March 15, 2011, 02:14:22 am
Title: R32 dials on 1.9tdi
Post by: harryralston on March 15, 2011, 02:14:22 am
Hi everyone ive just bought some r32 dials off ebay for 75 pounds and i am now wanting to put them in my 04 1.9tdi. is this possible and if so is there anyone near sheffield that could do it? thanks
Title: Re: R32 dials on 1.9tdi
Post by: GLIDN on March 15, 2011, 03:45:14 am
it can be done on one provision,
Have a look at your part number of your cluster.
Then have a look at the cluster number you bought.
Basically all the numbers need to be about the same, but the last three digits has to be only 10 difference.
Ie, 368 C will become 378 C
Then it can be fitted.
Post by: Eddie-NL on March 15, 2011, 06:31:14 am
As your car is an 04, it will be easy to do with Vag-Commander. What is the part number of the R32 Clocks?  if they end 960, 970, 961, 971, 962 & 972
Then Darren (MortyGTtdi) will be the man to see.
If they end with 3 or 4 then you will need to send them of to a company like shark performance for them to read the pin and reset the mileage
Post by: tony_danza on March 15, 2011, 10:38:46 am
You do realise it isn't going to make your 1.9d suddenly able to do 6750RPM  :signLOL:
Post by: Hedge on March 15, 2011, 10:52:07 am
Or sound like a throbbing V6. :signLOL:
Post by: pobmk4 on March 15, 2011, 11:48:45 am
Do the clocks not just read the normal rpm (although the dash obviously is clocked to more)?? i was thinking of doing this to mine too, but was unsure of what part numbers were compatible with each vehicle!!!
Post by: tony_danza on March 15, 2011, 11:52:17 am
I'd imagine things have moved on since I last wired in a rev counter, there'll be some sort of witchcraft in the clocks and a crank position sensor - so I'd imagine it'll read correctly.
Post by: Hedge on March 15, 2011, 03:23:04 pm
I think Darren has R32 clocks in his GT and I seem to remember him saying they read the correct rpm.
Post by: apollo13 on March 15, 2011, 03:25:34 pm
They will read the correct rpm but obviously you won't be able to rev the full range  :rolleye:
Post by: mortygttdi on March 15, 2011, 04:19:04 pm
Ya can try but it doesn't sound good :grin:
They work fine, its all electronic now so reads info from ECU and Canbus.
Darren
Post by: apollo13 on March 15, 2011, 04:51:06 pm
My nan would do it!! She only uses first and second gear  :rolleye:
Post by: Eddie-NL on March 15, 2011, 05:10:29 pm
does she kangaroo too :signLOL:
Post by: apollo13 on March 15, 2011, 05:13:57 pm
 :signLOL:
Yeah she does!
She's so deaf she can't hear the engine about to blow!!
