All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Gtiain on March 29, 2011, 06:32:35 pm
I ordered this part number- 1k0907530ad from 'car systems' in Poland. I've received this-
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi757.photobucket.com%2Falbums%2Fxx215%2Fgtiain%2F23801f45.jpg&hash=74193efecfb61bca45c5863670f21d90d8e81d58)
I guess this is not an ad revision and indeed c?
I'm pretty sure that the 7N0 parts are from a Passat.
It's the equivalent of an AD revision as it's date is 19-12-2010
Ok, so you think this will be ok bud?
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fww275%2FTaufe%2FScreenshot2010-11-17at002647.png&hash=01f18b820eede8f8a4945d0a53ba4cde7f68b386)
They are the compatible models and it was EOS i was thinking of not Passat.
Sorry for the complete numpty questions but will this fit my 06 plate?
As long as the shape is the same and the pins on the back are in the same place for the mounting plate then yes.
Just be aware when coding you need to take screen shots of each byte as that one will have 30 off the top of my head and yours will have 20. Some of the bits within the bytes will have moved around.
Right well it is Darren who is fitting it for me. I'll be mighty pissed off if it doesn't!
Thanks :happy2:
This is one of the newest ones, and the AD version is older than this
So instead of me thinking they've sent an older one they've actually sent me a newer one?!
Well I hope itll fit ok! :happy2:
Yes should be ok
about 10mins for Darren if that :signLOL:
7N0 is the new new sharan
I fitted one of these CAN Gateways to mine the other day
These modules do not employ the long coding method for setting what is installed. In long coding all you specify is whether the car is RHD and has 4 doors instead of 2
It is important that you screenshot the gateway installation list of your old can gateway, as this is how the new one is configured.
Ensure that all the boxes match up - steering assist has moved to the top of the list instead of 4 or so down so dont miss it out!
Youll need VCDS 10.6.3 or newer in order to code these gateways too
Darren are you listening?? :signLOL:
:signLOL: i had all hell getting it right, so wouldnt be fair to watch someone else struggle :happy2:
Do you mean the 7N0 gateway, or to code any gateway (from K on) that wasn't fitted aas standard?
The 7N0 gateway as this employs Gateway Installation List for coding similar to Audi's instead of long coding for installed configuration
Dead on. So a P version could be done using any version of VagCom?
Aye, but you should (if using a genuine interface) be using the latest software
Lol, a mate is doing it so I'm sure he doesnt have the latest.
I'm watching in the wings mate, :grin: but fitted so many of these you wouldn't believe :happy2:
Ian just remind me is your car DSG or manual?
Darren
Note: doesn't matter i've just looked at your sig and seen the DSG :happy2:
