All Things Mk5 => Mk5 General Area => Topic started by: cmdrfire on April 02, 2011, 07:12:19 pm
Title: Spare wheel well - another rust-prone location?
Post by: cmdrfire on April 02, 2011, 07:12:19 pm
Just had a complete clearout of my car, including (for the first time in ages - probably a good year and a half) the boot liner, boot floor, and spare wheel out. Found a good 30-40mm of water in the spare wheel well  :surprised: Some rust forming as well, though at this point it all looks like surface rust with no deep penetration.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Ffarm6.static.flickr.com%2F5022%2F5582248473_20cb637ab8_b.jpg&hash=bcdd122bc43f95e862334b125bc434eda811426a) (http://www.flickr.com/photos/cmdrfire/5582248473/)Spare wheel well (http://www.flickr.com/photos/cmdrfire/5582248473/) by CmdrFire (http://www.flickr.com/people/cmdrfire/), on Flickr
I've mopped it all out, and have left it all open for now to allow it to dry out whatever's left. Next week I'll go over it with a wire brush and see how deep it penetrates; if it's not too deep and it's only slight pitting then I'll POR-15 it all and won't have to worry about it again.
Not sure if this is common on Mk5s (people probably don't check that area too often) or if it's because of the OEM plastic boot liner I've been using since I got the car but some others with older cars may want to have a look (and I'm going to stop using that boot liner - the actual boot floor was damp to the touch when I removed it, so it could be the boot liner was the cause).
Title: Re: Spare wheel well - another rust-prone location?
Post by: 182_blue on April 02, 2011, 07:23:18 pm
Have you got a reverse camera
Post by: cmdrfire on April 02, 2011, 07:33:11 pm
Nope. I don't think it's from the hatch, in any case...
Post by: MAT ED30 on April 02, 2011, 07:38:33 pm
rear lights
Post by: cmdrfire on April 02, 2011, 07:42:11 pm
That's poss, especially as I have replaced the rear lamps with the LED clusters. I will investigate more during tomorrow's daylight... wish I had a garage  :sad1:
Post by: stealthwolf on April 02, 2011, 07:42:47 pm
I'm sure this has been mentioned previously but can't remember the cause.
Post by: stealthwolf on April 02, 2011, 07:44:53 pm
http://www.mk5golfgti.co.uk/forum/index.php?topic=17225.0
http://www.mk5golfgti.co.uk/forum/index.php?topic=18769.0
Post by: MAT ED30 on April 02, 2011, 07:46:01 pm
also check you rear washer tube like on the mk4 it use to split in the headlining and leak down
Post by: Jack Frost on April 02, 2011, 08:19:23 pm
It'll be the vent hidden by the rear bumper. I also had surface rust on mine. Open the boot and pull back the carpet then pour some water over the rear light and watch it come into the boot.
Cleaned mine up and sprayed with clear Wax.
Part is only about £8 if I remember correctly + whatever labour charges.
Post by: stealthwolf on April 02, 2011, 08:43:58 pm
Where is this vent and how do you access it?
Post by: cmdrfire on April 02, 2011, 08:51:41 pm
Thanks guys. I'll investigate this vent tomorrow. I'm going to book into VW next week for an oil/dsg fluid change and a compression check (  :scared: ) next week anyway so might get this sorted out while I'm there...
Post by: Snoopy on April 02, 2011, 09:19:02 pm
I cannot see it that well but are you sure its not just rust off the spare wheel thats stained the wheel well paint due to it sitting in the water?
Saying that the lack of paint on VWs it would not suprise me if the floors rusted
Post by: apollo13 on April 02, 2011, 09:24:08 pm
There is on one each side of the car AFAIK under the rear light and round a bit towards the filler cap.
You access them by removing the rear bumper, which in turn is accessed by removing the rear light clusters.
Post by: the bruce on April 02, 2011, 11:08:40 pm
Do so !!  :wink:
And watch if the rust is just on the surface (from the steel spare wheel).
Post by: cmdrfire on April 02, 2011, 11:10:56 pm
I don't think the rust is from the spare wheel, as it's in a couple of locations not contacted by the wheel, but my wire brush is at work (where my Karmann Ghia is stored) so will have to wait 'til next week to confirm... but it does look like only surface rust so cleaned and POR-15'd quite easily.
Cheers to all for the info on these bumper vent things... I can remove the rear light clusters easily enough tomorrow so might have a look there. If this is the cause I might use some silicone sealant to prevent further liquid ingress.
Post by: mb on April 02, 2011, 11:13:07 pm
If you pull the carpeted areas of each side of the boot out you will see the vents. You don't need to remove them fully to see the vents.
I had a leak in my boot which I traced to the passenger side vent which was replaced. Unfortunately, it didn't stop the leak. I then found the rubber tubing that carries the wiring from the body to tail gate wasn't seated properly in the car body so water was getting in there and running down on to the vent and then into the boot. I reseated the rubber tubing in the hole properly and haven't had a leak since.
Post by: the bruce on April 03, 2011, 12:30:39 am
The vents habe been a coomon problem on Mk.IV Golfs.
I never heard of any issue on a Mk. V.
Post by: magicmuffinman on April 03, 2011, 02:04:10 pm
Try popping out the gromet out of both the rear light that sorted mine out when I had half a foot of water in mine! Luckily I had soundproofed the boot which protected the metal!
Post by: cmdrfire on April 10, 2011, 10:57:19 pm
Bumpity to this, I had a good clean of the car yesterday and investigated and it seems the source of the water is in the two conduits carrying electrical cables from the vehicle to the hatch - they should be sealed securely to the vehicle but both of mine were flapping about. Water flows in through there and then into the spare wheel well!
I've secured one but on the other one the tab seems to be broken :S not sure how to fix it, but I might just apply a bead of silicon to seal them both.
...left the wire brush at work (I'm using it on my Karmann, which is stored there) and so didn't get a chance to clean it up; will do it next week I guess.
