All Things Mk5 => Modifications & Technical Area => Cosmetic/Interior Modifications => Topic started by: stevw1 on April 03, 2011, 11:41:49 pm
Title: Full fis clocks into a GT TDI
Post by: stevw1 on April 03, 2011, 11:41:49 pm
Can i get these to work in my GT TDI 140 05 plate?
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Ffarm6.static.flickr.com%2F5141%2F5586376091_193d201b04_z.jpg&hash=3404278b00d64e750af2adc068b9d8686aad5fc5) (http://www.flickr.com/photos/57689449@N05/5586376091/)IMG_6407 (http://www.flickr.com/photos/57689449@N05/5586376091/) by stevw1 (http://www.flickr.com/people/57689449@N05/), on Flickr
Any help is most appreciated  :wink:
Title: Re: Full fis clocks into a GT TDI
Post by: apollo13 on April 04, 2011, 05:18:45 pm
Not sure if they are  diesel or petrol clocks as Im not up on that part of the part number but 974 clocks can only be done by a specialist, unless they come with the SKC code??
Look for clocks ending in 970 971 or 972 and I and a few others on here can fit and code them.
Post by: stevw1 on April 04, 2011, 05:23:09 pm
I have the SKC Code and an eprom readout. Also have access to VAG-COM. They are from a Jetta TDI Highline i believe.
Possible ?
Post by: apollo13 on April 04, 2011, 05:24:47 pm
If you have the SKC then yes.
The VAG COM way of coding clocks is a little long winded though IMO.
http://wiki.ross-tech.com/wiki/index.php/Immobilizer_IV_Immobilizer_Swapping_(Instrument_Cluster)
Using VAG K+ CAN Commander to copy over the IMMO data is much easier and the only way I have done these swaps in the past.
Post by: stevw1 on April 04, 2011, 05:32:09 pm
Thats good, thanks for the info  :happy2:
At a later date i want to fit an mfsw from an R, will there be any issues ?
Post by: apollo13 on April 04, 2011, 05:34:43 pm
No issues at all.
You just need to make sure you have the correct slip ring, steering control module and airbag harness  :happy2:
Post by: stevw1 on April 04, 2011, 05:43:28 pm
HAPPY DAYS ....................
Wish you were nearer, sound like you know your stuff. You have a build thread? Interested in the headlights you have.
Post by: Andy on April 04, 2011, 05:47:52 pm
i have  a mk6 steering wheel that me and Darron swapped-he fitted it for me and i thing Eddie nl got the buttons working as well for his radio
Post by: stevw1 on April 04, 2011, 06:20:45 pm
Seems my VAG-COM guy is not au-fait with the MKV  :sad1:
Who is nearbye that can do it for me ?
Post by: apollo13 on April 04, 2011, 08:22:55 pm
Where are you mate?
As for my headlights, they dont make them anymore....only the halogen versions that don't turn or self level.
Mine use D2S bulbs like OEM Xenons.
Post by: stevw1 on April 04, 2011, 08:39:38 pm
Where are you mate?
Manchester M34
Bummer, bet they look cool  :smiley:
Post by: apollo13 on April 04, 2011, 08:42:46 pm
Yes they do  :grin:
I had a visit from someone in Devon for a MFSW and highline cluster swap........7hr round trip.
Post by: daboy3000 on April 08, 2011, 03:35:46 pm
My midline screen fades when its warm, if I just buy a set of TDi clocks off ebay can I just swap them around without any issues? Is the mileage stored elsewhere or do I have to change it?
Post by: apollo13 on April 08, 2011, 05:15:46 pm
No, the same rules apply when you upgrade any clocks. Even if its like for like the immobiliser info still needs copying over to the new clocks................but if your only swapping a midline for another midline (or highline for highline) you could just swap the front of the clocks over as the back part of the clocks contains the immo/mileage data.
Post by: Andy on April 08, 2011, 05:53:58 pm
I have a midline set of clocks for sale that i took out of my 54 plate gttdi
Post by: stevw1 on April 12, 2011, 03:13:19 pm
Right guys, i have taken delivery of these clocks today. By the date on the outer casing looks like they have come from a 2007 car, Jetta Highline i believe.
Can they be fitted and whos near enough for me to go to ???
Thanks Steve
Post by: apollo13 on April 12, 2011, 07:53:15 pm
If you have the correct SKC of the new clocks then yes they can be fitted.
You'll need someone with VCDS and a good understanding of how it works, look in the VCDS members section for people near you.
Lee.
Just to add, I think the VCDS way you only get one shot at coding the new clocks with the immo data. So its all or nothing.
I might be talking B.S as I've only used the k+CAN method but I'll have a read up on the VCDS method and report back.
