All Things Mk5 => Mk5 General Area => Topic started by: hoggj on April 05, 2011, 01:07:58 pm
Hey guys is there an easy way to change the front badge ? or if no easy way how is the best way ?Sorry guys found it in search history :( all dun.
My front badge was a simple 'twist and pull'.
This was on a 56 plate GTI, not sure on other versions
Rich
Thanks it was simple changed, now have a nice black vw badge :)
Push'n'twist risks breaking one of the clips on the badge. If you're not fussed, you can do it that way. Otherwise two screws at the top of the grille, two at the bottom (underneath license plate) and lift off. Then it's easier to change the badge.
Thanks mate I've just got a red gti badge also will need to remove the grill for that.
