All Things Mk5 => Mk5 General Area => Topic started by: GTIjames on March 05, 2009, 11:53:52 am
Title: New oem 'G' Diverter Valve fitted
Post by: GTIjames on March 05, 2009, 11:53:52 am
morning all,
had a few bits put on the car at jkm on monday good service as always   :drinking:
was always a bit worried that my diverter valve would go at some point with the mods i had done and noticed that the new oem revised edition dv was out and for £38 I thought you cant go wrong so had it fitted
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fu347%2Fjnewby99%2FNewDV1_big.jpg&hash=38ec69f3743611a28c959d15e863695623c9cc1c)
looks alot more purposeful than the original one so fingers crossed should hold up and fitting takes no more than 1/2 hour.
Is difficult to tell if there is any difference with it on as I had the apr fuel pump fitted at the same which has been more noticeable  :rolleye:
a cheaper option than the forge and it is of course a official VAG prouduct so for those worried about warranties is probably the best option, and is a must if you are mapping a standard gti with the dv valve next to the turbo, but if you want to fit a boost gauge then you will need the forge dv.
Title: Re: New oem 'G' Diverter Valve fitted
Post by: winrya on March 05, 2009, 04:26:21 pm
Thats not the G revision, its the new piston type for the new TSI engine
Post by: GTIjames on March 05, 2009, 04:40:25 pm
it fits the mk5 gti/ed30/a3/s3/cupra etc not sure about the new tsi though..
fitted nicely on my car too
just going by what i was told - it replaces the diaphram which was prone to breaking and causing boost problems.
http://www.jkm.org.uk/performance/divertervalves.htm
Post by: winrya on March 05, 2009, 04:48:24 pm
If you read this post http://www.golfgtiforum.co.uk/index.php?topic=104575.0 you will notice I went for the g revision rather than the new D version.  Basically it seems if it fits its lucky as its designed for a totally different engine.
Post by: vRStu on March 05, 2009, 10:23:58 pm
The D revision is also listed as being a replacement part for BWA engines.
Post by: neg on March 06, 2009, 11:08:29 am
BWA being the Ed30 ?
Post by: vRStu on March 06, 2009, 11:14:35 am
No BWA is the 200ps GTi engine but the GTi and the ED30 used the same DV
Post by: neg on March 06, 2009, 11:17:44 am
So AXX then BWA for 200, so this should be ok the AXX engine then.
Post by: vRStu on March 06, 2009, 11:19:07 am
Yep, as far as I am aware.
Post by: DanGB on March 07, 2009, 11:32:07 am
Bearing in mind you could of got it cheaper from a VW dealer :)
Post by: LaserBlue on March 07, 2009, 04:32:42 pm
well i got my G version from local dealers.. was £29.99, he also said this was the only correct upgrade valve for the standard GTI
Post by: CarrG on March 09, 2009, 11:49:52 am
morning all,
Off topic a bit i know but bet the APR FP made a massive difference in mid range kick?  :happy2:
What the cost of the APR unit and fitting?
Post by: GTIjames on March 09, 2009, 12:19:55 pm
morning all,
so far the pump has had an improvement in the mid-range, not massively but I have yet to have the new remap which makes the most of the pump (ie revo stage 2+). I am at Superchips this friday for this to be done, they should be able to turn the fuel pressure settings to 130bar which is what the apr pump can handle, once this has been done the benefits of the pump should be clearer  :evilgrin:
I went for the new apr fuel pump, not the exchange so I can revert the car and sell the apr pump when i get rid of the car in the future, cost of this is around £700 and £50 for fitting and testing.
Post by: CarrG on March 09, 2009, 12:29:18 pm
Ah very nice. Thanks for the reply.  :smiley:
Post by: cmdrfire on March 09, 2009, 12:46:12 pm
Needs moar forge.
Post by: bacillus on March 09, 2009, 01:25:31 pm
Just to be pedantic, the oem hpfp can deliver 130bar but only at higher revs... :happy2:
Post by: xxx_mojo_xxx on August 24, 2009, 05:39:44 pm
GTIJames - am I correct to think I can't fit a DEFI turbo gauge if I went for the OEM Rev D diverter valve?
Post by: GTIjames on August 24, 2009, 05:44:35 pm
no I fitted my defi gauge after the 'd' valve was installed.
I just use the forge kit to fit mine - http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=260303&product=FMBGFK2
was not aware of this when i wrote that post, all works well  :happy2:
Post by: xxx_mojo_xxx on August 24, 2009, 07:48:10 pm
I take it with the OEM rev. D design now being piston based - their is less of an argument to spend the extra dosh on the Forge diverter valve?
