All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: DanBoy on April 10, 2011, 11:51:48 am
Title: Aftermarket stereo won't turn off....
Post by: DanBoy on April 10, 2011, 11:51:48 am
Hmm got an interesting one here, I'm trying to install my Pioneer double din into my Golf and I've plugged it in to test it but it won't switch off, the moment I plugged the wiring into it it powered up straight away without the key in.
Now I've tried the usual red/yellow wires which I believe is just to sort out the memory but doesn't have any effect to this.
Any ideas???
From browsing around I seem to find people asking the same but no answers on how to solve it lol I'm confused....
Title: Re: Aftermarket stereo won't turn off....
Post by: vRStu on April 10, 2011, 01:04:23 pm
The two power supplies to the OEM quadlock are permanent.  The OEM units are switched over CAN.
Post by: Gene Hunt on April 10, 2011, 03:04:12 pm
Got this in mine but no problems with it? http://www.caraudiocentre.co.uk/productimages/zoom/AVIC_F920BT.jpg
Post by: DanBoy on April 10, 2011, 03:29:49 pm
What adaptor lead did you purchase to fit yours??
Post by: Gene Hunt on April 10, 2011, 03:33:56 pm
.........sorry Dan no idea it was in the car when i got it. I've had the car since December last year & no problems with flat battery etc.If it's any use mine only works with the ignititon on mate. :smiley:
Post by: DanBoy on April 10, 2011, 03:35:37 pm
No worries, will do some digging then lol just want it working properly now as don't want it constantly on  :grin:
Post by: Gene Hunt on April 10, 2011, 03:39:26 pm
Dan have a look on the Pioneer web site if you get no joy. www.pioneer.co.uk  they were helpfull when i wanted a new owners hand book. :happy2:
Post by: alexperkins on April 10, 2011, 03:52:23 pm
Youll need a Quadlock to ISO adapter that can generate the CAN signals into reverse, speed signal and ignition on/off
Alternatively, you can tap an ignition live from the fusebox
Post by: DanBoy on April 10, 2011, 04:20:45 pm
Ah cool I'll look for one of those, I did read about tapping a wire but didn't really fancy doing that if I can help it.
Post by: DanBoy on April 10, 2011, 04:40:39 pm
I've just found the correct bit of kit so just got to wait for it to arrive now  :happy2:
Post by: dub singh on April 16, 2011, 02:10:52 am
Had the same problem when i installed my Alpine Single din... HU had a constant supply which meant so did the amp...
Bought a CANBUS Adapter from Car Audio security for £40.. connects between the ISO connectors and problem sorted!
