All Things Mk5 => Mk5 General Area => Topic started by: Gtiain on April 13, 2011, 12:37:59 pm
Just seen the t shirts and they've done their job as I wasn't aware there was a problem with these. How do you check for signs of wear? Cheers
Remove t-shirt
Check for signs of wear.... commonly on the lower front, neck and armpit area
If signs of wear are minimal, you should be able to get away with a simple wash at 30 degrees.
Re-fit
Remove t-shirt
If no signs of wear are minimal, you should be able to get away with a simple wash at 30 degrees
Re-fit
:signLOL:
Very good
Very good rich lol
You have to take the HPFP out to access the follower...I think there is a reasonably good guide on here somewhere
"how to" section
written by VRS Carl :happy2:
