General => Random Chat => Topic started by: rich83 on April 15, 2011, 10:29:25 pm
Ok.. here goes!
One of the LEDs has broken on my nixie clock.
(https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc6/215175_10150151009265882_513100881_7168263_3304080_n.jpg)
Ive measured the voltage across the legs of the diodes. All measure 2.7-2.8V apart from the one that broken with reads about 1.4V.
Does this mean that its not illuminating becuase the voltage is too low, or is the low voltage reading a result of the broken diode?
Rich
Sounds like it's not illuminating because the voltage is too low.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Ffarm6.static.flickr.com%2F5067%2F5623012872_d851de0298_o.jpg&hash=eda3e36c57c8b3bb03c5248d604376fc3838f7ce)
Hmmm... i just dont see why its not getting the voltage. As you can see they are all connected up in parallel so if one wasn't working due to a voltage problem i would imagine none of them would work.
Need to take it to bits properly tomorrow to check for dry joints.
Are you measuring the voltage with the diode still connected? If so, disconnect the diode and measure voltage.
Yes the diode is still connected up.
If it's the blue LED then it could just be the diode that's failed.
Hedge.. D11-D16 on that diagram are the LEDs
In that case its the diode pulling the voltage down.
Do you have a multimeter?
What resistance do you measure across the resistor? Check also for conduction across the LED if you have multimeter that can do diodes.
Unlikely to be an LED failed unless it's been subject to high temperature for an excessive time while you were soldering (which can result in an eventual failure); more likely cause is a dry joint I'd guess.
edited 'cos i didn't see you measured voltage across the LED
I know. :wink:
Tested all LEDs with the Diode setting. The one that is broken gives a reading about 300... the working ones read 1500ish
Sorry hedge... internetz missunderstanding! :smiley:
Rich
im no electronics guru, i do big power, but ive dabbled with elctronics at Uni, id bet its as PDT says, to much heat cause and a poor connection/solder issue and will cause a volt drop over that diode.
Rich
Solution replace LED :P
Ok, what the hell is that clock all about??? I want one......but there expensive! Seem to be half built on eBay? Why does it look so funny?? :popcornsoda:
Thank neo. :happy2: Must have just been a dodgy component.
JackG... What the hells is it all about??? Its a clock! :signLOL: (i saw cmdrfires and had to have one)
Rich
I want one :party:
What a strange clock!............ I want one :party:
I enjoy going to sleep in the fading afterglow of the Soviet Union...
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Ffarm6.static.flickr.com%2F5010%2F5328588238_b960624b04_b.jpg&hash=c1250a580b714f82f4b4807fae0a3e6b7024f52c) (http://www.flickr.com/photos/cmdrfire/5328588238/)
nixie (http://www.flickr.com/photos/cmdrfire/5328588238/) by CmdrFire (http://www.flickr.com/people/cmdrfire/), on Flickr
On a historical note, Nixies were invented for numerical displays prior the advent of so-called "Numitron" tubes (an evacuated tube containing a number of tungsten filaments of the sort found in lightbulb), which themselves were used prior to the common availability of LED 8-segment displays for numerical indication.
Nixies are tubes filled with neon gas with multiple cathodes, each in the shape of a different digit. They're quite detailed and finely made works of art. Although Western production had largely ceased by the 70s, the USSR kept producing them all the way until the fall of the Iron Curtain. Most of the IN-8 tubes (which are used on my clock and on Rich's clock) were produced in the 80s. What's especially interesting is the driver for the Nixie tubes are solid state microelectronics, also produced by the USSR, which leads to an interesting juxtaposition of the 50s-era tubes being controlled by (relatively) modern electronics.
LED swapped and working! :happy2:
We need new pics then, Rich :happy2:
I want one :party:
x2
What a really cool gadget! :happy2:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Ffarm6.static.flickr.com%2F5102%2F5646157598_067f0488ee_z.jpg&hash=d57bd6236e2c5da3bc1e353e813850423fe332bc)
There you go... all working!
I still dont understand something though. With the broken LED in place i touched the legs of it with the new LED (effectively putting it in parallel) and it wouldnt light up. However once i had snipped the led legs to repeat the test the LED lit up. :confused:
Rich
