All Things Mk5 => Mk5 General Area => Topic started by: stevw1 on April 16, 2011, 08:24:41 pm
Hello. I want to put the Blue tint glass from the GTI / R into my diesel. I believe that my radio aerial is in the rear screen? Will this be possible with the new glass?? Is the windscreen blue too ??? Has anyone done this ????
Regards Steve :wink:
It will be quite costly I'd imagine, not really worth it as most people won't even notice.
And must cost a fortune too!
I'm sure if you found a car being broken you could pick it up for reasonable money.
As above big job as most of the glass is bonded & would need a proffesional to remove & re-fit.
I can get the fronts,rears and tailgate glass for less than £200. Windscreen is easy to source through Autoglass just fitting costs and the aerial issue
:wink:
