All Things Mk5 => Mk5 General Area => Topic started by: bodger00 on April 19, 2011, 06:13:14 pm
Title: Fitting S3 lower wishbones this wkend. Any tips?
Post by: bodger00 on April 19, 2011, 06:13:14 pm
As the title says...any tips? I am probably going to use the original bolts. Am I going to need the alignment checking afterwards?? or can I get away without having to have it done?
Title: Re: Fitting S3 lower wishbones this wkend. Any tips?
Post by: TrickGTI on April 19, 2011, 06:21:56 pm
Only tip I can give is you will need it adjusting afterwards any work on the suspension should require at least a check afterwards to see if it's all pointing in the right direction and as your making the wheel stick abit further out with the new arms then it should need adjusting  :happy2:
Post by: danishmkvgti on April 19, 2011, 06:29:38 pm
S3 lower wishbones/control arms are same length as the GTI ones . TT mk 2 are longer than GTI ones  :happy2:
Post by: bodger00 on April 19, 2011, 06:32:57 pm
That's what I thought Danish but with the added negative camber.
Post by: Hedge on April 19, 2011, 06:45:00 pm
Same as a normal GTI I thought. The negative camber comes from the TT arms because they are longer. :smiley:
Post by: TrickGTI on April 19, 2011, 06:46:18 pm
My bad sorry, had a small mind fart there  :ashamed:
Post by: danishmkvgti on April 19, 2011, 06:48:49 pm
Are the arms including rear mounts? If you want to remove them you need a hydraulic press to do so  :happy2:
Post by: bodger00 on April 19, 2011, 07:32:21 pm
These are what I am hoping to fit:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fae235%2Fbodger00%2FIMAG0190.jpg&hash=37451aa483462d19761f278a8ebe0b1f37a97432)
I am after a reduction in unsprung weight so the negative camber idea was a added side effect to me. I assume these are just a case of unbolting the orignals and bolting these on. If there is no difference in length and camber then should I really need the alignment checked?
Post by: danishmkvgti on April 19, 2011, 07:38:54 pm
I would say no, but if in doubt then measure the one you take off with one of the S3. As you are using the S3 rear mount there's no need for the hydraulic press.  :happy2:
Post by: TrickGTI on April 19, 2011, 07:39:52 pm
Yes you would be supprised how much changing like for like can put it out. Even just unbolting everything and putting it all back together can knock it out a touch.
Post by: bodger00 on April 19, 2011, 07:51:45 pm
Cheers guys I guess I will just have to fit them and see.
Thanks for the advice and I am glad I don't need a hydraulic press.......I can get access to a trouser press but not a hydraulic press :smiley:
