All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: DaveR77 on April 26, 2011, 01:42:53 pm
Title: Which CAN do I need for RNS510 C
Post by: DaveR77 on April 26, 2011, 01:42:53 pm
I've just put a deposit down on an Edition 30 (Jan 2007) and want to buy an RNS510 version C. I assume my car will need a newer CAN to avoid any problems, which version should I get
Title: Re: Which CAN do I need for RNS510 C
Post by: danishmkvgti on April 26, 2011, 01:50:15 pm
this one is the newest one on ebay.de atm, but i have the AH revision (made in march 2010)
http://cgi.ebay.de/Audi-Steuergerat-Gateway-1K0-907-530-AF-Gateway-Temic-/130504976331?pt=Autoteile_Zubeh%C3%B6r&hash=item1e62b3e7cb
Post by: DaveR77 on April 26, 2011, 01:55:03 pm
cheers, is L the lowest needed for the RNS, best check what I have first before ordering a new one!
Post by: alexperkins on April 26, 2011, 02:31:09 pm
K is the lowest needed not L, though not all Ks are suitable.
Its likely yours will already have a K
Youll need to scan your CAN Gateway with VCDS and post up the SW and HW revisions of it.
Mine had a K and it was absolutely fine.
Post by: danishmkvgti on April 26, 2011, 02:34:39 pm
I had a K in mine and it wasn't fine  :wink:
Post by: alexperkins on April 26, 2011, 02:35:12 pm
What build month was yours danish?
Post by: danishmkvgti on April 26, 2011, 03:23:44 pm
12 month 2005  :smiley:
Post by: alexperkins on April 26, 2011, 03:26:39 pm
Ah early then
2007 cars are generally ok on a K  :happy2:
Post by: RagingKileak on April 26, 2011, 03:28:35 pm
I'm also wondering about this whole CAN Gateway thing. I have a 2007 Ed 30 (dunno what build or exact month as I am at work) and I want to be sure I won't get stupid issues following fitting BT and RNS510 etc.
Don't have any way of scanning though, sigh.
Where does the CAN Gateway live? Is it a DIY swap or need coding/hard to locate?
Matt
Post by: DaveR77 on April 26, 2011, 03:31:18 pm
Right, bought the RNS, i'll give it a go before changing the CAN
Post by: alexperkins on April 26, 2011, 03:32:14 pm
Can Gateway is hidden behind the relay/fuse box.
Accessible by removing the wiper motor and the access panel beneath it
Post by: Resonance on April 26, 2011, 05:30:06 pm
My eyes are stuck to this thread, I have a Feb 2007 Edition 30 and want to upgrade to a RNS510 at some point and this thread should answer my question about the CAN gateway issues  :laugh:
Post by: vRStu on April 26, 2011, 05:38:24 pm
Do you take the back wheels off when you top up the oil or is it just CAN gateways you like to take your time over  :evilgrin:
The Gateway is accessible from inside the car.  :happy2:
Post by: apollo13 on April 26, 2011, 05:39:47 pm
Or just get to it above the pedals.....
Unless you have an early car and then they're sometimes behind the ashtray/cubby area.
EDIT-Stu beat me to it  :signLOL:
Post by: DaveR77 on April 26, 2011, 05:49:57 pm
I'll let you know, probably won't get the unit til next week thanks to the wedding so i'll fit it next weekend
Post by: alexperkins on April 26, 2011, 06:15:15 pm
Id have given you £50 quid if you could get to my can gateway. Some retard had cable tied it to the back of where the access plate is
There was absolutely no way in hell I could have got in there, be it from the top or via the pedals - believe me I tried.
I dont take the wheels off for oil top ups, but I take the exhaust off when I change the spark plugs though  :signLOL:
Post by: Eddie-NL on April 26, 2011, 09:25:13 pm
On some cars it is near the bulkhead
http://www.r32oc.com/tutorials-guides/30166-canbus-gateway-location-removal.html
Post by: vRStu on April 26, 2011, 09:28:33 pm
I can get to it from the front even in that location, not easy granted but less hassle than going in through the scuttle.
Post by: SteveP on April 30, 2011, 02:15:36 pm
What HW and SW versions on a K gateway have been proven to work?
Got a car with the following version : -
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 060107F1001787
   Coding: 3F3F034007001003
   Shop #: WSC 00066 000 00000
   VCID: 2F69457DC5DD
No fault code found.
Post by: DaveR77 on May 05, 2011, 06:11:07 pm
Mine is the following - same as SteveP
   Revision:   H04 02    Serial number: 281106F1001231
   Coding: 3F0F034007000001
   Shop #: WSC 01287 785 00200
   VCID: 2F671974C78D
Post by: alexperkins on May 05, 2011, 06:47:55 pm
I believe you have to have HW with a 21 signature for it to work - thats what mine had and it was a later K revision
Whats the build date of yours?
Best thing to do is try it and see
Post by: DaveR77 on May 05, 2011, 07:03:33 pm
Jan 07, not gonna do any harm trying  :scared:
Post by: alexperkins on May 05, 2011, 07:05:47 pm
You *might* be ok, but its possible you wont be as March 07 was when the later K units were installed
Worth a shot  :happy2:
Post by: DaveR77 on May 05, 2011, 07:14:23 pm
Are there any other signs apart from draining the battery, I think I read it switches itself off randomly too?
Post by: alexperkins on May 05, 2011, 07:22:58 pm
Symptoms....
It wont show the Welcome to Volkswagen boot screen after it has booted the first time
It'll drain the battery
It can randomly restart
It can also switch off
Post by: DaveR77 on May 06, 2011, 09:02:17 am
Gonna buy one to save the hassle, is AH the latest? How much are they from the dealer?
Post by: danishmkvgti on May 06, 2011, 09:06:01 am
To expensive from the dealer, in Denmark i was quoted 150£ for one, about half price on ebay.de  :smiley:
Post by: DaveR77 on May 06, 2011, 09:42:13 am
The AA+ ones are about £110 in delivery on ebay.de at the moment
Post by: alexperkins on May 06, 2011, 11:07:22 am
http://cgi.ebay.co.uk/CANGATEWAY-1K0907530AA-CAN-GATEWAY-RNS-510-RCD-510-/170601532805?pt=UK_AudioTVElectronics_GPSSystems_GPSSystems&hash=item27b8a4cd85#ht_3131wt_1141 (http://cgi.ebay.co.uk/CANGATEWAY-1K0907530AA-CAN-GATEWAY-RNS-510-RCD-510-/170601532805?pt=UK_AudioTVElectronics_GPSSystems_GPSSystems&hash=item27b8a4cd85#ht_3131wt_1141)
When I ordered that, I received a 7N0 variant which is out the new EOS and is bang up to date
Remember, you only need a gateway newer than a K so an L onwards will work a treat. Theres little advantage to having the latest revision in our cars
Post by: DaveR77 on May 06, 2011, 12:37:50 pm
ta, ordered one of those, dealer said £158 for an AF, AH wasn't on his system
Post by: alexperkins on May 06, 2011, 12:44:38 pm
You will need 10.6.3 or higher VCDS to code this gateway btw just to make you aware  :happy2: These are the newer gateways that user the Installation List instead of Long Coding to set the configured options
Post by: DaveR77 on May 06, 2011, 12:54:56 pm
Yep, I've got the latest VCDS  :happy2:
Post by: alexperkins on May 06, 2011, 01:06:41 pm
Then its happy days  :wink:
Post by: DaveR77 on May 07, 2011, 10:51:29 am
Symptoms....
OK, RNS is fitted and working  :happy2:
Should it show the welcome screen everytime I turn it on? It doesn't at the moment
Post by: SteveP on May 07, 2011, 10:52:27 am
Only after 1 hour of the ignition being off, my revision K gateway appears to be working fine.
Post by: DaveR77 on May 07, 2011, 10:54:39 am
cheers, so if I go back in an hour or so and it shows the welcome screen it should be okay?
Post by: DaveR77 on May 07, 2011, 12:29:41 pm
Well it showed the welcome screen  :happy2: fingers crossed!
Post by: DaveR77 on May 07, 2011, 02:04:50 pm
Does anyone know what setting I need to set in VCDS to get Nav on the MFD? I've added Navigation (37) to the CAN gateway, I thought that was all that was needed. There's no audio on the MFD either
Post by: Eddie-NL on May 07, 2011, 07:09:17 pm
Do you have a Full height MFD (Highline)?
If you do, then check the coding in the RNS and see if BAP is ticked. If it is untick it and reboot
Post by: DaveR77 on May 07, 2011, 07:45:10 pm
Yeah highline, I can't find bap tickbox, is it under navigation coding?
Post by: Eddie-NL on May 07, 2011, 07:54:21 pm
Go into navigation > Coding > Long Coding
Restart the RNS after making changes
Post by: DaveR77 on May 08, 2011, 06:38:07 pm
I think I must be blind! Does anyone have a screenshot of what I should be unticking?
Post by: StephenED30 on May 08, 2011, 06:42:26 pm
Take a look
http://www.mk5golfgti.co.uk/forum/index.php/topic,9350.msg147077.html#msg147077
Hope it helps.  :happy2:
Post by: alexperkins on May 08, 2011, 09:34:23 pm
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fss4%2Fmortygttdi%2FByte7.jpg&hash=4abb9cd6ac68970dc6c4314763fc76072eb8615c)
Its on the last byte in the Long Coding on 37 - Navigation
Notice at the bottom where it says BAP - you need to untick this
Post by: DaveR77 on May 09, 2011, 06:58:32 pm
Done that but still nothing on the dash, is there anything else I need to do?
Post by: SteveP on May 09, 2011, 07:04:21 pm
Did you have an audio menu before installing the RNS?
Also did you reboot the RNS after changing the coding?
Post by: DaveR77 on May 09, 2011, 07:10:39 pm
Yep, had the audio menu on the original stereo. How do you reboot?
Post by: SteveP on May 09, 2011, 07:12:00 pm
These three buttons on the top of the unit   < + > + i
Post by: alexperkins on May 09, 2011, 07:12:17 pm
You need to reboot the RNS with the ignition on by pressing eject and the left & right arrow buttons simultaneously  :happy2:
Then turn ignition off and on and it should work
Post by: DaveR77 on May 09, 2011, 07:15:16 pm
Yep, reboot worked, cheers for all the help  :happy2:
Post by: alexperkins on May 09, 2011, 07:16:38 pm
No worries
