All Things Mk5 => Mk5 General Area => Topic started by: Rampage on April 28, 2011, 02:10:33 pm
Title: MFD2 and playing Ipod lists
Post by: Rampage on April 28, 2011, 02:10:33 pm
Hi Team,
I've read for those that have the MFD2 unit with Ipod prep, you can only use the first 5 playlists on the unit and pressing the CD6 is a kind of mind of mix play.
Don't think I've read it anywhere, but I discovered by accident on the way home yesterday that if you change your Ipod to whatever Playlist you want to listen to (could be Playlist no. 12 for example), if you select it, then put your Ipod back into the unit...
It will play that selected Playlist via CD6! So pleased I discovered that, thought I was going to have to endure the same 5 playlists forever more...   :jumpmove:
Rampage
